It is currently Thu Apr 26, 2018 4:30 am
 Post subject: rose jointed track ends
PostPosted: Thu Nov 29, 2012 5:59 pm
i know people say you get what you pay for :blahblah:
but how would these fair up?
Ebay Linky
the bush on standard rod ends must take a beating when the car is lower, so surely these would be a better bet?
PostPosted: Thu Nov 29, 2012 6:12 pm
Track rod ends are one of the things that don't get effected that much when you lower the car, the way they wear out of by lateral forces when turning the wheel. But in most cases, its only really the bush that will fail, then that will lead to bearing failure bascially.
Those ebay ones are probably alright to be fair.
PostPosted: Thu Nov 29, 2012 6:13 pm
Danny to the Rescue!!!!!!!! :D
what size would i need homie? ill probably end up getting standard ones when i go to get my wheel bearings etc but its just for the future really darling :)
PostPosted: Thu Nov 29, 2012 6:21 pm
Those ones you posted up will probably be fine to be fair.
The bit at the bottom of their page doesn't fill me with great hopes though saying if you want higher quality ones that bascially last more than a couple of months check out their other items. So it could be said these are cheap and nasty. Personally I would just stick with normal standard items, they will probably be cheaper too.
PostPosted: Thu Nov 29, 2012 6:24 pm
yeah definetely bud :) im always put off by stuff like that on ebay just incase they are shit... just wanted to check for the future when i want to tweak bits and make bits better/stronger :D
PostPosted: Thu Nov 29, 2012 6:34 pm
Best bet would be to keep the standard ones, they are probably going to be as strong as you will ever need, and also well projected. They will probably last 5-10 years no problem too if you get a decent make.
Rose jointed bits would be more for a track based car where you are just upgrading all the parts - but to actual decent expensive parts which can take a ton of abuse and never fail on you. Rallying springs to mind with stuff like that, think how much the steering wheel and wheels are moving, and how much abuse bits will get over the course of one stage, let alone 10 or 12 that the car might have to go through on each event. Thats when rose joined parts are needed because standard items would just wear out in no time.
Bit of a ramble there :)
PostPosted: Thu Nov 29, 2012 6:47 pm
completley get it. thats why getting rose jointed lower arms would be silly, but getting polybushed ones would better (camber adj optional there too!)
Danny, have you not thought of making a few sets up, make some money? id happily pay for camber adj lower arms yano. i know its effort but just a thought :)
PostPosted: Thu Nov 29, 2012 7:04 pm
Lower arms are slightly different, they take a lot of abuse from the road when you drive the car, the better option would be rose joined ones, but they would be very stiff and could make the car harsh to drive daily, polybushes would give a bit of flex so a softer ride, and still a lot better than standard bushes because they are more than likely never going to fail.
I have yeah, but there isn't enough people interested to be fair, plus its pretty easy to do yourself, once you have got an angle grinder to the bolts and removed them it just requires a load of effort to file the holes. Plus there isn't a huge profit margin unless you want to rip people off, which I don't like doing. Of course I could sell them for loads of money and make a half decent profit, but then they wouldn't sell because people could go out and do them theirself for a lot less.
PostPosted: Thu Nov 29, 2012 7:51 pm
yeah i was going off what phil said. since mine would be a daily driver i wouldnt want to ruin the ride!
ok mate. well i know you made a guide so i guess ill have a crack myself :)
