It is currently Tue Jul 17, 2018 7:13 am
 Post subject: Sump removal
PostPosted: Mon Nov 26, 2012 11:33 pm
Right you tarts, simple question.
How the fuck do you get the sump off when your engine is in the car?
I've dropped the exhaust, removed the starter and alternator. Undone all the bolts but I just cannot for the life of me get the thing to clear the alternator bracket/pas bracket/engine mount bracket. Its loose and moves about but won't come off!
Anyone who's done this have any tips as I can't be the only poor bastard who's come across this!
Haynes book of lies is, as usual, no use. Just tap and lower clear my arse!!
Cheers in advance
Paul
 Post subject: Re: Sump removal
PostPosted: Tue Nov 27, 2012 12:16 am
substitute tap for 'twat' :) im sure someone will pop up with the answer but maybe its just brute force needed?
PostPosted: Tue Nov 27, 2012 12:23 am
Tried brute force! Problem is then getting the fucker back on ;)
Paul
PostPosted: Tue Nov 27, 2012 6:04 pm
true but once its off surely you will then see how to get it back on :)
PostPosted: Tue Nov 27, 2012 8:51 pm
Drives: 2litre Si
If I remember when I changed my rod bolts it was a pain to get off, ended up lowering it trying front and rear first but ended up having to leaver it off with aid of piece of wood, can't remember what it got stuck against, also to get it back on had to use a piece of wood and a jack under the sump to push it back on.
PostPosted: Tue Nov 27, 2012 9:43 pm
Cheers for that Will, might come to that if loosening everything doesn't work.
PostPosted: Thu Dec 13, 2012 2:56 pm
loosen the gearbox bolts as well,ive had this problem a couple of times
PostPosted: Thu Dec 13, 2012 3:01 pm
Hi mate,
Yeah, in the end I took off the front engine mount to block bracket and loostened the gearbox bolts around 10-15mm and levered the block and box apart.
Came off a dream then!
Cheers
Paul
