It is currently Wed Jul 18, 2018 12:28 am
 Post subject: brake fittings
PostPosted: Mon Nov 12, 2012 6:56 pm
lads, need m13 brake fittings to connect 2 of the pips up on the mondeo servo. however, i cant find any. are they referred to as fitting a copper pipe that's '3/16' ?
the flaring kit i got doesnt have a 13 either. and i cant seem to find a size 13 anywhere either.
thanks in advance.
Ben
 Post subject: Re: brake fittings
PostPosted: Mon Nov 12, 2012 8:11 pm
Drives: 2litre Si
What size is the actual brake pipe and are you talking about connecting direct into the master cylinder? Wouldn't thought it be 13 mm possibly 10mm?
PostPosted: Mon Nov 12, 2012 11:07 pm
the originals are 10mm will, but two of them need to go to 13mm (according to fiestaguides) into brake unions.
size of the brake pipe is just the standard size that came with the 1.4, no idea lol!
PostPosted: Tue Nov 13, 2012 9:19 am
Drives: Nissan Pulsar GTi-R
13mm for a brake union, sounds odd. Have had a look about online and can't find any. You absolutely sure it needs a 13mm size? If it was in a Mondeo, surely there would be some about. The only way you can get it close to 13mm is if you go imperial and get something relatively close, but that's not guaranteed to work. 13mm is about half inch (a size you're well used to so I've heard :P )
PostPosted: Tue Nov 13, 2012 9:59 am
Drives: 08 Ford Focus 2.0
^ lol :lolz:
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Tue Nov 13, 2012 2:23 pm
Good luck getting 13mm unions!
PostPosted: Tue Nov 13, 2012 7:23 pm
haha thanks Des. heres the link on fiesta guides that says i need m13
http://www.fiestaguides.co.uk/content/m ... inder.html
PostPosted: Tue Nov 13, 2012 8:09 pm
Drives: mondeo st tdci
i fitted a mondeo master cylinder to the mk2 fit fine i got mine from halfords with iirc 3/16 brake pipe
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_753207_langId_-1_categoryId_255228
PostPosted: Tue Nov 13, 2012 8:23 pm
Um, you had these on it when I sent it to you!
PostPosted: Tue Nov 13, 2012 8:26 pm
scrub what i said i just had a look at my project thread pics and they do look bigger on on set
PostPosted: Tue Nov 13, 2012 9:48 pm
ahh shit yeah youre right! think ive lost one though haha! nooooooo! what size are they dan?
thanks anyway big g!
dan, i still need to flare the pipe anyway! :(
PostPosted: Tue Nov 13, 2012 10:13 pm
flaring the pipe to the standard size, the union is still 13mm on two though.
PostPosted: Tue Nov 13, 2012 10:19 pm
ye that sounds about right
PostPosted: Tue Nov 13, 2012 10:53 pm
so i dont need to flare it to 13mm? but wont the fitting slip off?
yeah i have one, i put the other somewhere, hopefully not the bin! if not ill take a trip to a scrappy and get one
PostPosted: Tue Nov 13, 2012 11:45 pm
The union and it's thread is a different size, the size of the pipe doesn't change and neither does the size of the flare.
PostPosted: Wed Nov 14, 2012 9:36 am
Was going to say, you don't need to flare the pipe to 13mm!!! :o
The flaring tool simply moulds the shape of the pipe to whatever union you put on the end (there's a few different types of flare, male, female, etc), and then the size of the union is the 13mm you're being told to put it to.
Worst case scenario, get to a scrappies with a Mondeo in and chop them off :)
PostPosted: Thu Nov 15, 2012 3:37 pm
Yeah, get to a scrappy with some wire cutters and cut 3 or 4 of the fucckers off and pick the best ones, then flare onto your pipe... Simples!!
Paul
PostPosted: Thu Nov 15, 2012 9:07 pm
shit yeah, i really dont think sometimes. thanks Dan.
good point Des, will do that!
lol Paul, you know it. i should be able to find it, but spares could always come in handy :)
PostPosted: Fri Nov 16, 2012 10:02 pm
Ben mate, to settle all confusion regarding this, the unions are 12mm, still uses 3/16 pipe and you flare it to the pipe size not union...
if you need some, i think i got a couple from when i done this conversion will have a look tomorrow :)
Users browsing this forum: Bing [Bot] and 6 guests
