It is currently Mon Jun 18, 2018 5:05 am
PostPosted: Fri Nov 09, 2012 12:01 am
chaps.
few things that have been on my mind that i want to clear up...
first off is the egr... the two prongs on the back of the ho inlet. can they be left open or do i need to connect a tube between the two?
secondly are the hoses in the engine bay. ive ordered 8... how many are there all together?
thirdly is the clutch arm assembly. anybody got a pic of it so i can piece it together?
im sure i will have plenty more, but as i am only able to work in the dark during the week i can only do a bit at a time! thanks, Ben
PostPosted: Fri Nov 09, 2012 12:27 am
The egr pipes on the inlet need a pipe between them, or something like that. Might be info about it on the egr removal guide on here, or 1.6 - 2.0 converion guide also on here. Cant remember what I did.
Hoeses - someone else can answer.
Clutch... what do you need pics of exactly? its goes flywheel > clutch plate > pressure plate > release bearing.
PostPosted: Fri Nov 09, 2012 8:32 pm
My kit was 6 hoses and this included the rocker cover to the air box so that plus the two I got made (stat to matrix and water rail to stat) would make all 8.
PostPosted: Sat Nov 10, 2012 1:54 pm
thanks Danny, i put a pipe between the two, just wanted to check if that was ok.
i mean the clutch arm that the cable connects to.
thanks Paul, how many pipes are there meant to be though in the engine bay? just wondering if ill need more or if i can re use some of my 1.4 ones.
PostPosted: Sat Nov 10, 2012 5:48 pm
The clutch arm can only go on one way. There is a little cut out on the splined pole thingy majig which the bolt goes through, and it will only go through with the arm in 1 position.
With regards to that pipe on the inlet, look up in the conversion guides, because I'm sure something needs doing with it. It is mentioned in one of the guides.
PostPosted: Sat Nov 10, 2012 5:58 pm
Found the info/pic about it. Pipe between both :)
PostPosted: Sat Nov 10, 2012 8:39 pm
sweet, thats what i did nice one :)
yeah the arms attached, but the big metal block on the end. ill do it lol, just wanted to see a pic so i dont have to stand there trying to figure it out! :D
PostPosted: Sat Nov 10, 2012 8:45 pm
If you haven't figured it out by tomorrow afternoon/evening I'll send you a picture when I get back to mine.
PostPosted: Sat Nov 10, 2012 8:52 pm
ok mate nice one.
also, the speedo cable goes into the bit on the gearbox doesnt it?
going to replace all the female and male brake unions. are the all m10 front and rear?
PostPosted: Sat Nov 10, 2012 10:32 pm
Nah the speedo cable goes into the heater vents, it detects how fast the air is going through the vents and thats how it shows your speed.
Why are you going to replace all the brake unions? As the saying goes, don't fix it if it ain't broke!
PostPosted: Sat Nov 10, 2012 11:04 pm
Danny I'm no fool haha.
They're rusted to fuck though mate. may as well since I'm doing all the brakes
PostPosted: Sun Nov 11, 2012 12:01 am
:lol: DAYUM!
Fair enough buddy, don't know what size they are off the top of my head at the moment. GOOOOOOOOOOOOOOOOGLE :)
PostPosted: Fri Nov 16, 2012 10:08 pm
all brake unions male and female are M10x1.0 obviously they come in different pipe sizes also, make sure you get the 3/16 fittings, but as said in another thread, 2 fittings are m12x1.0 for the mondeo servo mod
PostPosted: Sat Nov 17, 2012 3:36 pm
Drives: 2004 Volvo S60 D5
You know the EGR removal thing, i've blanked off the back of my inlet in the same way. However my question is... what do you do with the modules which were connected there, one side goes into a little multi plug thing and then to the EGR (which is removed) and the other side goes into a mini canister which is also multi-plugged, then goes to a black box in the o/s wing (i think it's a pulse air system). There is also a pipe going from the canister to the rear of the car somewhere parallel with the brake pipes.
