It is currently Fri Jan 19, 2018 12:35 am
 Post subject: supporting zee car
PostPosted: Fri Nov 02, 2012 1:22 pm
guys and dolls...
rear beam is coming off today. however, because i cant be arsed going outside to check, where can i put the axle stands to support it? the fronts on stands atm btw.
thanking you
 Post subject: Re: supporting zee car
PostPosted: Fri Nov 02, 2012 2:08 pm
Just in front of where the arm bolts to the chassis is where I usually put the stands when jacking the back up, should work fine with the beam off.
Paul
PostPosted: Fri Nov 02, 2012 2:10 pm
Depends how high you want the car really.
Picture here of jacking points - never jack on points C though, just because its a fiesta :lol:
Points B at the rear is where you can put stands - there are 2 chassis rails there to support the car. I always put stands at points B towards the front and jack up under the lower arm carriers. Never knew you could jack up under the front valance though, new to me! That might save loads of time. Might try that in the future for race car style jack ups! Well actually, with the splitter thats a massive no go :lol:
PostPosted: Fri Nov 02, 2012 2:13 pm
Point C is where I was meaning for the axle stands.
I always jack on the valence. Would recommend a bit of 2x3 or the likes as a buffer as the valence is a bit soft (read rusty) and the jack will burst it.
Paul
PostPosted: Fri Nov 02, 2012 2:25 pm
sweet lads nice one. should of checked the haynes tbh lols!
will get cracking then!
PostPosted: Fri Nov 02, 2012 4:02 pm
Drives: Si 1.6 & ST170
For points B at the rear you may need to putblocks under the axle stands as its quite a distance to get the vehicle raised high enough to work under and remove the rear beam. Just make sure your on a flat surface!!!
The Loumiester wrote:
PostPosted: Fri Nov 02, 2012 4:22 pm
Drives: Like a boss
Just be fucking careful you knob jockey!!
PostPosted: Fri Nov 02, 2012 4:25 pm
Drives: Sideways
Feel the love :lol:
...he's right though ;)
AUTOBAHNSTORMERS
PostPosted: Fri Nov 02, 2012 6:06 pm
cheers louis. i have a few chunky blocks i can whack on top :thumbsup:
ta wayne... love the way you care but you say it horribley so it doesnt look like youre being a puff :teehheee: nice one
will do woodsy! couldnt get it done today because its been hailing and lashing it down and the rear of the car isnt under the carport :frown:
PostPosted: Tue Nov 06, 2012 3:59 pm
Depending on the blocks mate, you might be better actually putting them on the ground and putting the axle stands on the blocks if you know what I mean.
Safer than big blocks balanced on small axle stands
And just ignore them, be as unsafe as you like, its only your legs ;)
Just kidding bud, make sure its well supported as a rusty fuel tank in your face would never be fun!
Paul
PostPosted: Tue Nov 06, 2012 7:56 pm
Thanks Paul. yeah ive put the stands on 4 stack of bricks, sits pretty nicely. not too high but just right!
