It is currently Wed Jul 18, 2018 11:17 pm
 Post subject: tappy engine
PostPosted: Sun Oct 28, 2012 12:29 pm
is it me or do fiesta have tappy engines lol i know mine aint got tappets
 Post subject: Re: tappy engine
PostPosted: Sun Oct 28, 2012 2:23 pm
If they have hydraulic tappets then no they don't.
If they are the old style kent engines then yes they do.
PostPosted: Sun Oct 28, 2012 7:58 pm
Drives: mondeo st tdci
hows ur oil level ?
PostPosted: Mon Oct 29, 2012 8:09 am
oil level is fine i know my clutch bearing needs doing so clutch kit it is? not sure to just get the clutch kit or a complete clutch
PostPosted: Mon Oct 29, 2012 8:54 am
Drives: Nissan Pulsar GTi-R
A clutch kit IS the complete clutch, friction plate, pressure plate and release bearing. It'll be the release bearing making the noise, and while you're doing that you may aswell do the rest.
As for noisy top end, just how noisy is it? Don't forget you'll have the noise injectors make, they can give the impression of a noisy head.
PostPosted: Mon Oct 29, 2012 9:43 am
I'll second that.
There's been a few times i've been listening to the engine and thought, christ the tappets are a bit noisy and it's only on closer inspection I've realised its just the injectors.
They are ticky little buggers ;)
As for judging how noisy yours is, get down to a garage that has a couple of them and pretend your interested. Get them started up and listen under the bonnet. That way you get a couple of engines to listen to and compare with yours ;)
Or if you know someone with one, get a listen to that too :) Not the most scientific way to check, but the more you can listen to then the law of averages works in your favour!
Paul
PostPosted: Mon Oct 29, 2012 10:20 am
Injector noise is often overlooked :lol:
Have a look at some YouTube video's of the same engine running, as an alternative to finding them in real life too :) Good call though from Paul, the more you listen to, the more you know if yours is noisier or quieter or average.
One more thing to note, you say the oil level is fine, but what grade are you using? If it's too thin on the top end of the heat range it will make things a bit noisier :)
PostPosted: Mon Oct 29, 2012 8:22 pm
cheers guys the noise aint that loud its just a little tappy sound lol more anoying then anything lol as for the oil,l i havent serviced the car since i got it as my mot is due in december so that first,whats the the best oil to use etc.i know ngk or good spark plugs to use when i come around to servicing it.I got the car on 100,000 miles iv done the cam belt as thats the main worry on any second hand car apart from that iknocked him down to 350 with 1 owner since new and full service history from 2000.
http://i1309.photobucket.com/albums/s64 ... -00205.jpg
PostPosted: Tue Oct 30, 2012 8:54 am
Well, if you want to take a video of it and post it up we can have a listen, but I'll be better it's just general running noise and the sound of the injectors. At 100k the engine won't sound quite as smooth as it once did, but unless the sound is quite audible, then I'm going to say I wouldn't worry.
As for what oil to use, it's supposed to take 5-30 I do believe. You can consider going a little thicker though now you're on higher mileage.
PostPosted: Tue Oct 30, 2012 6:16 pm
ok buddy nice one
PostPosted: Tue Nov 06, 2012 3:48 pm
Drives: 08 Ford Focus 2.0
10-40 is always a good bet :)
FACT wrote:
Ben Elvin "Jam" wrote:
