It is currently Fri Jun 22, 2018 10:14 am
PostPosted: Thu Oct 04, 2012 2:58 pm
Drives: Fiesta RS Turbo
i have changed the clutch cable twice on the RS but still crunching in reverse, now another cable the peddle is only coming up
about 2 inchs when engaged. had the clutch checked out and is ok, but someone told me the quadrant could be f**ked.
any ideas as dont want to change the quadrant yet as its a s**t of a job.
PostPosted: Sun Oct 21, 2012 9:32 pm
to be fair i have no idea what a 'quadrant' is but every time i put a new clutch cable on my si i always adjust the foot pedal under the dash so it sits the same hight as the brake pedal. that way i get no clutch slips and no crunches!
TEAM AUBERGINE
PostPosted: Mon Oct 22, 2012 2:36 am
Adjusting the quadrant will help with pedal height and where the bite point is. If that doesn't help it might be worth looking at the linkage and adjusting it slightly to see if that helps - 10mm bolt and it can be moved to whatever position you want, mine only need moving a couple of mm for it to be non crunchy.
PostPosted: Mon Oct 22, 2012 9:58 am
Danny,
What do mean move the linkage??
Do you mean turn the arm around on the box? I thought the splined shaft was keyd so it could only go on the right way?
Paul
PostPosted: Mon Oct 22, 2012 10:29 am
I'm on about the actual gear linkage under the car :)
PostPosted: Mon Oct 22, 2012 12:26 pm
Ahhhh.... the light comes on.
Wonder if I should move mines a little bit then, bit crunchy sometimes, but then my quadrant is on its way out too so that's probably not helping :lolz:
Oh, the joys the joys :)
Paul
