It is currently Wed Jul 18, 2018 1:53 pm
PostPosted: Sat Sep 08, 2012 9:55 pm
the gearbox mounts are completely solid so i can't use the poly flex stuff i bought.
but for the engine mounts im a bit stuck. can you remove the rubber bit from both engine mounts to be able to fill the hollow bits? i tried very hard but i couldnt lol! do you have to leave them in the brackets to do it?
thanks, Ben
PostPosted: Sun Sep 09, 2012 10:54 am
If there is a bolt in the middle then yeah you can remove it, if not then leave the bracket on.
