It is currently Tue Jun 19, 2018 11:40 am
 Post subject: oil pressure light
PostPosted: Wed Aug 29, 2012 11:43 pm
Drives: 1.6 si, mk2 fez
hello bit of a weird one I'm driving around my recently got 1.6si and whilst changing the oil + filter I noticed the oil pressure switch has no plug or wire anywhere to or for it so I was hoping someone could take photo of where the wire goes into the loom so I can try to find where its hiding or so I can repair
thanks will.
I WANTS BOOST!
 Post subject: Re: oil pressure light
PostPosted: Thu Aug 30, 2012 9:19 pm
its normally part of the loom that has the coilpack plug, cps and coolant temp gauge sensor, brown with green stripe with right angle connector
PostPosted: Sat Sep 01, 2012 9:50 am
ok thank you, ill try to trace it over the weekend :thumbsup:
I WANTS BOOST!
PostPosted: Mon Sep 03, 2012 7:01 pm
Just found the wire cut really far back in the loom, acquired a plug from my local scrapyard and wired it up, all is good thank you for the help :thumbsup:
I WANTS BOOST!
PostPosted: Sat Sep 15, 2012 10:03 am
all sorted m8?
PostPosted: Sat Sep 15, 2012 10:00 pm
Yeh it's working now, it did stop working but I replaced the pressure switch and all is good :)
I WANTS BOOST!
Users browsing this forum: Baidu [Spider] and 6 guests
