It is currently Wed Jul 18, 2018 9:42 am
PostPosted: Sun Aug 05, 2012 10:11 pm
Drives: 1.6 si, mk2 fez
helloo, really im hoping that someone can either post the link to a thread i read a while ago on filling the mounts with a sikaflex type thing or if someone can just explain to me what to do here :P
thanks will.
I WANTS BOOST!
PostPosted: Sun Sep 02, 2012 11:20 pm
I filled all the spaces in my zetec mounting with Tiger Seal, as suggested by someone else on here, to try to make it more robust. Not used that car on the road yet, but just broke the standard mounting on my other 'temporary' 2.0 Si, so will be doing the same to the new mounting for that sometime this week. I just put cling film underneath it on a flat surface then filled it up to the top. Used most of a tube, and took quite a while to fully cure (also quite smelly while the solvents were evaporating).
PostPosted: Mon Sep 03, 2012 6:59 pm
ok thanks I was going to use something like that but since I bought this polyurethane moulding kit which comes with 2 bottles you mix together it pours like water takes 60 mins to fully cure at room temperature, it also only cost £15 so I'm hoping this will work
I WANTS BOOST!
PostPosted: Mon Sep 03, 2012 9:17 pm
Sounds like that's what I need. I'm a bit worried the Tiger Seal won't be set by the time I need to use it at the weekend.
PostPosted: Mon Sep 03, 2012 9:24 pm
Drives: Jap Crap
Indeed - viewtopic.php?f=13&t=23265&p=296526
PostPosted: Tue Sep 04, 2012 10:15 pm
Here's the link to what I got, I haven't tried it yet as Ive not had time
http://www.mbfg.co.uk/polyurethane-rubbers/3808.html
I WANTS BOOST!
Users browsing this forum: Baidu [Spider] and 9 guests
