Fiesta-Si.com • View topic - RS Turbo ~ Boot
It is currently Sat Jun 15, 2019 11:54 pm
 Post subject: RS Turbo ~ Boot
PostPosted: Sun Feb 26, 2012 9:11 pm
Ok long story so will shorten it down.
Basically saw a few bubbles of rust on my boot and was going to be sending it off for smoothing and thought i would take the rear window out myself, MISTAKE 1, totally smashed the back window.
went to the scrapyard to get a second hand window when they offered me a boot with no rust of a tidy mk3, with only front damage. now ive tried everything in my power to make the fcuker fit, can not get it to lie up at all, or when i do it wont go onto the lock mechanism, now ive swapped the lock over from the rs and messed about with the position of the mechanisms but cant for the life of me get it to work. Ash
 Post subject: Re: RS Turbo ~ Boot
PostPosted: Mon Feb 27, 2012 10:23 am
should fit no problem, only difference in the mk3 boots is the early mk3 bootlid and the later mk3.5 bootlid, the mk3.5 has cables coming throught the top of the boot aswel as the bottom, is the new bootlid you bought bent on the inside ??
PostPosted: Mon Feb 27, 2012 5:00 pm
no its straight throughout, fits like a dream just can get it it shut.
PostPosted: Mon Feb 27, 2012 9:37 pm
Have you adjusted the stricker plate on the slam panel?
PostPosted: Tue Feb 28, 2012 4:22 pm
i adjusted mine on there, doesnt shut without a fair bit of force. not saying to slam it as you might smash another :P
PostPosted: Thu Mar 01, 2012 9:40 pm
yeah ive moved it quite a bit, when i take it off the boot lines up ok :/
PostPosted: Sat Mar 03, 2012 10:46 am
must be that then, make sure its central too
PostPosted: Wed Mar 07, 2012 3:06 am
daft one...
just check the pin on your original boot and new one are the same .... failing that try get the glass out :lol:
PostPosted: Sat Mar 10, 2012 11:13 pm
ive tried to use both boots neither will no go on, so ive got one ultimatum, pin it down :)
PostPosted: Sat Mar 10, 2012 11:14 pm
good plan b like!
PostPosted: Sat Mar 10, 2012 11:31 pm
If you don't use it much use those springs that stretch onto a hook but mount them inside
A mate did this on his mk1 with a fiberglass boot to hide it was fiberglass :D
