Fiesta-Si.com • View topic - hissing noise coming from inlet area
It is currently Fri Mar 27, 2026 10:36 am
PostPosted: Tue Sep 28, 2010 4:43 pm
hi guys,
wondered if someone could help me, i have a 1.4 8v Si and recently its been running rough.
It has a dramatic loss of power now (50mph flat out) and a hissing sound coming from the inlet maninifold area, but no1 can seem to find any leaks or anything. I need some help asap and its gettin worse and worse, i dont want to lose my Si
cheers
PostPosted: Tue Sep 28, 2010 6:11 pm
sounds initially like a air leak to me, good way to find out if it is, is to spray WD40 or easy start around the inlet area and see if the revs rise, if it does definatly an air leak somewhere
PostPosted: Tue Sep 28, 2010 6:54 pm
As mentioned try the above, if it is then take it off and check the gasket etc and refit.
PostPosted: Tue Sep 28, 2010 8:45 pm
check your vacum hoses are not split
PostPosted: Wed Sep 29, 2010 2:26 pm
have tried spraying around the inlet but nothings happening, will check the vacuum hoses tho, i just hope it isnt major.
thanks anyways
PostPosted: Thu Sep 30, 2010 9:34 am
try a new inlet gasket :thumbsup:
PostPosted: Sun Oct 03, 2010 3:57 pm
may have just found the problem, the noise has been gettin worse and now the noise can be heard just on tick over and it seems to be coming from the exhaust. Noticed there isnt any pressure coming out the back, so my guess is the cat is blocked and its forcing the air back up??
PostPosted: Sun Oct 03, 2010 7:15 pm
Could be something to do with your EGR, i have the same problem... although mine is coming from the release valve.
http://www.fiestaguides.co.uk/phpBB2/vi ... c01d8f1604
I'll do a video in a min :)
PostPosted: Sun Oct 03, 2010 8:17 pm
PostPosted: Sun Oct 03, 2010 9:44 pm
my si had this is wouldnt do any more than 30mph and cat was blocked
PostPosted: Mon Oct 04, 2010 2:02 am
thanks for help, will let ppl knw what we find
PostPosted: Fri Oct 08, 2010 12:45 pm
anyone know what causes the cat to block? why would the inside collapse?
PostPosted: Fri Oct 08, 2010 12:53 pm
they just can do over time :doh:
PostPosted: Sat Oct 16, 2010 12:22 pm
thanks for the help, it was the cat collapsed, i got a new one for £60, all fitted now and all power is back
