It is currently Mon Jun 25, 2018 8:24 pm
PostPosted: Thu Mar 10, 2005 1:22 pm
is it possible to fit a Escort RST Turbo on my 1.6 si?
or would i need a frst turbo and maniford?
If In Doubt, Flat Out
PostPosted: Thu Mar 10, 2005 2:36 pm
Drives: V70 T5
think you've put this in wrong section try technical problems not guides.
PostPosted: Thu Mar 10, 2005 3:38 pm
what as in to turbo charge the 1.6 what work are you planning on doing internally?
this depends on what you can do on std internals and management you can run 4psi without killing it, i wouldn't use anything above a t2 for this as it would be pointless
PostPosted: Fri Mar 11, 2005 1:33 pm
i just hoping someone would help me, tell me wot i need to do. my mate has a spare turbo of his rst and is sellin it for ?50 so i just wanted to know if i bought it how easy would it be to fit it, or does it require major engine work?
PostPosted: Fri Mar 11, 2005 2:32 pm
Drives: V70 T5
you'd be better off fitting the 2ltr mate, and then turbo that. cos a turbo'd 1.6 Si is gonna struggle to make N/A 2ltr power without changing heads etc.
to turbo the 2ltr, ideally you'd use low comp pistons, but you can use a de-comp plate, erst exhaust manifold, you'll need the head re-tapping for this, then different management as the std stuff can't really cope with positive pressure.
PostPosted: Fri Mar 11, 2005 8:12 pm
guessing that doesn't count as help then :look:
PostPosted: Sat Mar 12, 2005 2:56 pm
Yes and get a professionalto put it all in
I have a smooth sack mmmmmmm! cool beanz
PostPosted: Sat Mar 12, 2005 4:50 pm
Drives: V70 T5
as said above really, weird how he hasnt replied
PostPosted: Sat Mar 12, 2005 8:44 pm
:lol: maybe he's finished and joined the frst forums instead :P
PostPosted: Mon Mar 14, 2005 12:48 am
cheers, just wanted to know how easy it was, i've got a 2.0 pinto so i'm gonna strip it down and rebuild it with full race cams and stuff in so will tell you how i get on
PostPosted: Mon Mar 14, 2005 2:36 am
Why not a Zetec? Much newer and more emissions friendly :D
Pinto lmao that should be in a Mk2 Esci RS
