It is currently Tue Jul 17, 2018 4:50 pm
PostPosted: Sun Mar 06, 2005 10:34 pm
Out of interest..
What sort of rev's in 3rd gear does you Fiesta SI 1.6 16v "drop off" ?
Mine seems to be dropping off slightly at 4000 revs in 3rd gear,
Picking up from 4000 in 4th gear, dying off at 4500 in 4th.
Taking the revs from 4500 to 5000 in 5th gear and slowing increasing upward.
But it seems a bit sluggish.. maybe Im expecting too much? (Not had the car all that long)
Paul
PostPosted: Sun Mar 06, 2005 10:55 pm
Drives: V70 T5
mine seems to pick up at 4000RPM, in any gear. runs out of puff at around 5500 though.
PostPosted: Mon Mar 07, 2005 3:05 am
Drives: Nissan Pulsar GTi-R
Mine picks up at around 3k, gets good at 4k and drops off about 5.5-5.8k :)
PostPosted: Mon Mar 07, 2005 12:13 pm
Starts going at about 3k ends around 5.5k i suppose :) 8-)
PostPosted: Mon Mar 07, 2005 1:17 pm
Drives: 170bhp RS
same as des :wink: but i have torque all over the revs really, it'll pull from 20mph in 5th eeeeasy. :D
PostPosted: Mon Mar 07, 2005 4:59 pm
valvers will always be more efficent at producing power higher up the rev range, thats where they were designed to produce the power,
also valvers have a problem with maf sensors causing flat spots at about 3500-4000 rpm, a new maf will usually sort this and help it pull stronger through the rev range
PostPosted: Mon Mar 07, 2005 5:08 pm
mine tails off as the rev limiter kicks in :P
PostPosted: Mon Mar 07, 2005 5:13 pm
yes but your valver has a turbo bolted to it does help a little bit :devil:
PostPosted: Mon Mar 07, 2005 7:45 pm
Sorry is maf..
a - Mass air flow sensor?
I wouldn't of linked the two together, if maf is an air sensor?..
Where can one find this sensor if thats what it is? Not on the intake?
Let me know please thanks v much :)
PostPosted: Mon Mar 07, 2005 8:29 pm
Drives: 170bhp RS
the thing circled in white is your MAF sensor. yes it's its short for Mass Air Flow sensor, and it tells your ecu how much air is coming into the engine, and mostly likely what tempterature too, but not 100% on it. If it's fault it wont be getting the air/fuel ratio exactly right so will run a little 'off'. :lol: technical term.
the Si has a fair amount of torque between 3k-4k, which is nice to be able to drive with pace without revving the engine hard. but as tony said, to get a 16v to really get going you need to rev it, and hard :devil: i can feel mine really pick up at 4000 ish (hopefully feel it a little more now its chipped) :D
if you're not very happy with it, give it a general service. it could be plugs or leads not giving it great performance. :)
PostPosted: Mon Mar 07, 2005 8:32 pm
there you go scotty sorted that, what piower you hoping witht he chip scotty what else you done other than stack it?
oh and uprate your brakes!
PostPosted: Mon Mar 07, 2005 8:39 pm
Drives: 170bhp RS
id like close to 100bhp with chip fitler and the magnex. :lol: doubt it'll be that good though. although it does go better than all the others. ill have it rolling roaded when i can to see whats it chucking out.
brakes are on the list when the 15s are on. 4x4 cossies dont fit under the pimpin' 14s 8-)
PostPosted: Tue Mar 08, 2005 11:36 pm
Thnx for those pointers scotty,
yeah next step is the plugs as i dont think they have been done for a long time.
Already given it a oil filter and oil change.
The air flow sensor was already on the "induction kit" when i bought it so i may swap it for the sensor that was on the original air box/intake pipe.
Leads look ok so wont both with them, might check them for resistence but really doubt its them.
Going to book the car in at work for plugs changed,
Change them myself at work, if one happens to snap.. oh dear, not my problem, companies problem, let them sort it out *angel*
Paul.
PostPosted: Tue Mar 08, 2005 11:57 pm
nice attitude and why not. prob worth changing your leads aswell they dont cost much well not as much as mine ?60 a set from ford :o and special order :x
they do thend to break down inside though but you'll still get a spark as its strong enough to jump gaps will just be weaker.
hope it all goes well
PostPosted: Fri Mar 18, 2005 8:29 pm
Got some lucas silicone type leads off eBay, don't suppose they are anything special but might do the trick.
Got some ngk sparks from halfrauds, just gota spray half a can of spray stuff in each to loosen them off, they are incredibly tight..
Paul
PostPosted: Sat Mar 19, 2005 4:32 pm
Drives: V70 T5
apparently the best leads to use are standard ford ones, dont know how much they are though.
but tony's right they can break down but still give a spark. just not a good one.
PostPosted: Sat Apr 02, 2005 2:06 pm
I whacked some NGK plugs in, and put the lucas leads on, with standard leads but new plugs it was a bit more torquey, and with new leads just felt smoother which is always good!
so yeh i think it quite likes me for changing the plugs now.
