It is currently Fri Jul 20, 2018 1:54 pm
PostPosted: Thu Oct 16, 2008 4:43 pm
This little thing here. Im sure you must be able too because you can order it from ford on its own as seen below, and if you can, can you change it for one slightly smaller? If you was to have a bearing that was slightly smaller - because it obviously houses a bearing inside.
Reason is, as you might or might not know, im replacing my gearbox because my one is fooked, and the release bearing is different on the old gearbox to my new one that i have when i changed my clutch about 2months ago. The new release bearing wont fit over this retainer thing because the diameter of the inside of the bearing is too small. So i need to swap the retainer thing over to make it fit.
