Fiesta-Si.com • View topic - MK4 Windscreen fit mk3? YES.
It is currently Thu Mar 12, 2026 2:15 am
PostPosted: Wed Jul 23, 2008 11:10 pm
Right problem in getting hold of a mk3 windscreen quick at moment :( need it in time for early next week and struggling
Had a look at some mk4 windscreens and they look the same size as the car really isnt much different to the mk3, they have a smaller windscreen rubber as they are also bonded onto the car.. sooooooooo I was thinking, mk4 windscreen and bold it onto the mk3 and use either mk3 or mk4 rubber seal depending
Ive read a few people saying they fit and some say they dont
any info much appriciated!!!
cheers
PostPosted: Sun Jul 27, 2008 9:34 pm
No matter.. MK4/5 windscreens do fit, no matter what anyone says.
PostPosted: Fri Aug 01, 2008 10:14 pm
can u use the mk3 rubber or does it need bonded?
PM if u want u advert here :D
PostPosted: Fri Aug 01, 2008 11:36 pm
PostPosted: Sat Aug 02, 2008 12:16 am
Used the mk4/5 rubber. Bonded the window into the lip.
Only thing I can say it from the interior you can see a gap around the edges, if you used a mk4 dash you wouldnt see this. although you could mod the mk3 rubber to go around just the inside of the screen to cover this i guess :)
PostPosted: Sat Aug 02, 2008 7:55 am
just change the dash m8, easy to do, i got the mk3 dash out in literally 10 minutes, u should change the heater assembly to if u want heat :D
did u get a normal screen or is it heated? 8-)
PostPosted: Tue Aug 05, 2008 4:01 pm
