It is currently Sat Feb 16, 2019 6:09 pm
 Post subject: MOT FAQ's
PostPosted: Sat Apr 16, 2005 1:47 am
After a few recent discussions on the forum i have decided to write a few of the more trick questions to answer
Lighting
rear foglights
rear must be present if only single must be on the midline of the car or towards the drivers side. must show red
front foglights
these can be fitted and not functional. they are not included in the test
indicators
must illuminate orange no matter what colour of housing.
spotlights.
if fitted these must be functional and operate with the main beam
reverse light
you do not need one as it is not part of the mot test
all lights (this one i think is great)
if all lighting is disconnected or blanked off it will not be taken into account on the MOT and you will pass. although driving at night is at your own risk
braking
abs
if abs system is fitted the dash light must fucntion correctly
if the abs system has been removed the dash light must function correctly but when removed it will light up permanently, this is beacause it wrk on a normally closed loop, so simply bridge the connector and it will work fine
front brakes
pads must not be worn to less than 1.5mm
discs must not be heavily pitted, grooved or lipped
any cracking etc of the disc will result in immediate faliure
rear brakes
must work and have no more than a 45% bias to the rear.
hand brake
must have adequate reserve travel and must physically stop the wheels
lines
these must not be kinked dmagaged or heavil corroded
common question
my car failed its MOT on braking performance but the garage wont give me a precise estimate to fix it!
This is beacause no dismatleing is allowed during the MOT so unless the damage is visable it could be many unseen things
mechanical
Lower arms/ball joints
if your lower arms are knocking and are deemed to be excessively worn you will fail.
CV joints
any leaking or incorrectly seated CV joints will need replacing to pass an MOT
structural
arches
if your arches are rusted to the point that they are flaking you will fail as this is a hazard
rust
excessive rust (full penetration) withing 30cm of load carrying suspension mounting points will need corrective work
excessive rust within 30 cm of seat belt mounting points will need corrective work
cills
any full penetration rust will need corrective work
floorpan and major rust patches bigger than 10cm in diameter will need corrective work
seat belts
if fitted from factory rear selt belts have to be present if the seats are still fitted to the car
harnesses.
aslong as they are fully uk road tested and carry suitable certification it will be fine if in doubt anything FIA spec is usually fine
Anything else you can think of post up and either myself or the admin will update the post
HTH Tony :D
PostPosted: Sat Apr 16, 2005 1:48 am
Drives: Nissan Pulsar GTi-R
Great stuff there Tony, very useful :)
Will stick it in FAQ's for people to have a look at, and it will be immortalised forever :lol:
PostPosted: Sat Apr 16, 2005 8:52 am
Drives: V70 T5
Great guide there mate, will come in handy when my MOT's due. think only thing it will fail on is underside rust. but thats gonna get done when i get paid out.
PostPosted: Sun Apr 17, 2005 11:37 am
Tyres
(I think most people know this anyway - but thought I'd add what I know)
Must have a tread of at least 1.6mm across the central 3/4 of the width of the tyre.
Any cut in excess of 25mm (or 10% of the width of the tyre, whichever is greater) and is deep enough to reach the ply cord, will result in a defective tyre - ie fail.
HTH too :)
PostPosted: Sun Apr 17, 2005 4:48 pm
v. useful post mate, just out of intrest, you say "foglights can be there but not working" does it matter if there are no front fogs at all???
thanks alot
PostPosted: Sun Apr 17, 2005 8:22 pm
thanks alot
Nope :) The only one that has to be present is the rear fog light.
PostPosted: Sun Apr 17, 2005 11:17 pm
just what i was hoping for :devil:
cheers
PostPosted: Sun Apr 17, 2005 11:22 pm
Headlights - the beams must be correctly adjusted.
You can only check this on a beam setter (a device with a lens and gauge - most MOT places with adjust your lights for free) - And if you have auto adjusting / electric headlight adjustment - save yourself some bother and set it to "0". (not neccesarily a fail enless you catch them on a bad day!!)
Windscreens - any crack in the drivers portion of the screen which is larger than x cm big will give you a fail. (all depends on the size of your windscreen. Remember safety first if you have any sizeable cracks its best to replace the entire lot.)
Brake light - central - if a central brake light or high-level brake light is fitted and connected it must show red and work correctly (i.e if it only half glows this can deem a fail)
Mirrors - You must have internal mirror, and one other mirror e.g drivers side wing mirror and internal mirror. (enless van or other)
So if you are missing a wing mirror you are ok. (if the mirrors are cracked this will more than likely fail you)
Wheel bearings - must not make excessive noise - if noise can be heard the chances are you will fail.
(Above are from my experiences at work of how we MOT test. I believe them to be correct but dont hold me to it in a court of law.. disclaimer here* lol)
PostPosted: Tue Feb 19, 2008 11:34 pm
whats the deal with windscreen wipers?
My gf's rear wiper isnt working and shes got MOT in a few weeks. Pass or Fail?
PostPosted: Wed Feb 20, 2008 8:12 am
Should pass as it's not a requirement to have rear wipers. No mention of rear wipers in the MOT Manual:
http://www.ukmot.com/6-1.asp#Text_top
PostPosted: Wed Feb 20, 2008 10:11 am
yeah there not checked, as some cars don't come with them! :)
 Post subject: Re:
PostPosted: Thu May 15, 2008 7:09 pm
Drives: FORDS
[quote="Mattyboy"]yeah there not checked, as some cars don't come with them! :)[/quote]
if there is an arm and wiper are present then some garages will fail it for that reason, best option it to remove the arm and cap it :)
 Post subject: Re: MOT FAQ's
PostPosted: Fri May 16, 2008 6:14 pm
for a car mot the rear wiper is NOT a testable item..
PostPosted: Mon Sep 14, 2009 7:08 pm
Drives: Fiesta ZS
Quick question, Leaks..
I have a leak which is going to require the gearbox to be taken out, its an oil leak, and only a few drops come out slowly but surely. I think engine stop leak has done the job for a little bit.. I should really check, but if its in the MOT and leaks a bit will that fail?
 Post subject: Re:
PostPosted: Thu Oct 15, 2009 1:52 pm
Drives: Fiesta Si 16v
I thought you HAD to have drivers side mirror and one of either interior or passenger side??
correct me if im wrong please :) ?
Grant
 Post subject: Re: Re:
PostPosted: Sat Oct 17, 2009 12:00 am
[quote="G-Muzzy"]Mirrors - You must have internal mirror, and one other mirror e.g drivers side wing mirror and internal mirror. (enless van or other)
Grant[/quote]
Your right on that.. where did this info come from? lol
PostPosted: Sun Mar 14, 2010 7:58 pm
How about window wiper/screen washers, does it matter if they don't work, my motor has gone i think so i have a silent button.
PostPosted: Sun Mar 14, 2010 8:10 pm
Drives: Like a boss
are your sure its gone or could it possible just be blocked, can you hear any noise when you press the washer button?
PostPosted: Sun Mar 14, 2010 8:15 pm
Na its dead when you press it, main fuse is fine so i thought it would be the motor.
PostPosted: Sun Mar 14, 2010 8:30 pm
Drives: Like a boss
oh right, only a 2min job to change it dude, spend more time getting to it. lol
