It is currently Sat Feb 16, 2019 3:57 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Jan 19, 2009 1:12 am
Drives: 16v Si & S2 RST
it seems my 1.6 lump has finally given up, smoking very badly now, so im going to drop a new lump in at the weekend, luckily my mate broke a 1.8 xr2i and still has the engine, maf, tb, ecu etc... will i need to swap the injectors over still?
PostPosted: Mon Jan 19, 2009 9:10 am
imo i'd just drop/swap what ever is on the 1.8 16v engine into your engine bay eg, inlet,maf,injectors, tb etc.
but you might have an issue with the ecu, as iirc the 16v 2i's might be similar if not the same as the RS1800 and come with external edis, where as the 16v Si is internal, so you might have to swap the engine bay loom as well with all the sensors, easy enough when you dont have anything in the bay ;)
if i'm wrong i'm sure someone will correct me :D
PostPosted: Mon Jan 19, 2009 10:39 am
ah that might be a prob then as hes only got the engine, inlet, exhaust manifold, tb, maf and exu left over
it will probably work out cheaper to do the 2L if ive got to start changing looms about, plus im opnly paying my brother £50 to swap it :lol:
PostPosted: Mon Jan 19, 2009 11:41 am
it will work on the 1.6 Si ecu, i know the 2.0's work on the 1.6 ecu but the fueling isn't right, iirc it leans out on the top end
but imo if your chaning engine i'd go for a 2.0 its not that much more difficult than dropping the 1.8 in, unless you can get hold of a 16v 2i loom then you can slap some 2.0 cams, 2.0 tb and maf on the 1.8 and have a 130bhp spec(pretty much the same as the RS1800)
PostPosted: Mon Jan 19, 2009 12:05 pm
it might be a pain in the ar*e sourcing all the required parts in time really, tbh i just need to get it running so ive got it for work, its only going to be a daily driver in the next few months anyway
a friend of a friend might be picking up a 1.6 zetec escrt estate, so hopefully thats the silver top and not the black top engine and ill just drop that in. ill prob do the usual bits to make it breathe more easilly, ive got a decat pipe already waiting to go on. is there any interchangable parts from the 1.8 2i that will help? inlet, exhaust mani, tb?
PostPosted: Mon Jan 19, 2009 12:08 pm
[quote="onslack"] it will work on the 1.6 Si ecu, i know the 2.0's work on the 1.6 ecu but the fueling isn't right, iirc it leans out on the top end
but imo if your chaning engine i'd go for a 2.0 its not that much more difficult than dropping the 1.8 in, unless you can get hold of a 16v 2i loom then you can slap some 2.0 cams, 2.0 tb and maf on the 1.8 and have a 130bhp spec(pretty much the same as the RS1800) [/quote]
actually now youve said that, what if i use all the bits my mate has and get a mondeo 1.8 ecu from the scrappy? would that work and take away the probs you said about?
PostPosted: Mon Jan 19, 2009 1:08 pm
everything from the silver top zetecs is interchangable, but how they perform on the car is another matter, as ideally you want the correct ecu to deal the correct fueling etc etc.
you could try that and see if it works, only thing you'll have to look out for is if the 1.8 mondeo ecu has external pats or not as thats the issue we have with the 2.0 conversions, only 3 known ecu's from 2.0 mondeo's work with the Si's wiring etc
but as to which 1.8 ecu's work i dont have a clue, suck it and see i guess :lol:
PostPosted: Mon Jan 19, 2009 6:09 pm
Drives: MK1 Focus Estate Ghia
If your gonna xr2i 1.8 zetec engine it... and you have access to all the bits..
Just do a full change of everything including loom as I bet the xr2i has external pats
But fear not!!
Most of the RS1800 ECU's are for external pats. (which are cheap)
So all you'd need is the MAF, TB, RS1800/Escort 130spec GTI/2.0ltr CAMS, and RS1800 external pats ECU and your sorted ;)
(Although the 130spec Escort GTI ECU's will work... Not sure if they are internal or external EDIS or not.. I'm guessing internal because they were the last model so would work on the Si wiring loom)
OR.
You could fit the xr2i 1.8 zetec engine, and run it on the 1.6 ECU on the current internal edis loom.
Just don't try go near the redline as it would lean out and send it wappy.. Although I ran mine for 3 months like this!
Then you could upgrade it to 130spec and either run it with a DESK DEWY or DEEP 2.0ltr ECU (as I have seen a few people run the 130 spec 1.8's with no problems - which would be easier to get hold of...) or get hold of an internal EDIS RS1800 ECU which is code CULT (admitedly rare as rocking horse poo..)
I'd say 2.0ltr it for the sake of it... but if all the parts are there from the XR2i 1.8 then its rude not to. 105bhp to start with :)
PostPosted: Mon Jan 19, 2009 7:34 pm
[quote="happypaul"]
[/quote]this does sound like a good option actually as for 1 he would practically give it to me anyway and the other bits shouldnt be too pricey
just so ive got this right the only other bits i would need are;
dewy/deep/desk ecu
2.0L maf
2.0L TB
2.0L injectors/rail
130 spec cams
he did say when he picked the car up to break, it was alot quicker than his current 1.8, the fella he got it from said about a stage 2 head (he said he doesnt beleive anything he said as hes known to exaggerate) but it may even possibly have the 130 cams, is there markings on the ends to tell what they are?
PostPosted: Mon Jan 19, 2009 7:51 pm
Do a search on here or FT.com
They have the codes for the cams.
Both the 130spec 1.8 ones and the 2.0ltr cams are identical tho.
You dont need the 2.0ltr fuel rail of Throttle body.. although you can mod the 2.0ltr TB to fit if you want to do that.
The zetec fuel rails are the same on all the fiesta's, its just the injectors that are different flow rates.
Soo...
dewy/deep/desk ecu (or RS1800 CULT if you want to run on the Si loom)
2.0L maf (If your going 130spec, you'll need the proper maf if running 1.8 ECU, or 2.0ltr MAF if using 2.0ltr ECU)
2.0L TB (dont need it, but it will fit with modding)
2.0L injectors/rail (fuel rails are the same..just get the 130 spec injectors or 2.0ltr ones. although tosave the ecu playing up.. if using 1.8 ecu get 130 spec ones, or if using 2.0ltr ecu use the 2.0ltr injectors)
I think that makes sense.. it does to me anyway :lol:
130 spec cams
PostPosted: Mon Jan 19, 2009 8:15 pm
check in here for all the parts you require :halo:
viewforum.php?f=10
PostPosted: Mon Jan 19, 2009 8:42 pm
cheers for the info, much appreciated :)
[quote="onslack"]check in here for all the parts you require :halo:
viewforum.php?f=10[/quote]if all goes well and i get the engine ill prob have a couple of bits off you, have you got the injectors as well?
PostPosted: Mon Jan 19, 2009 8:45 pm
stick a post up in my thread and i'll answer there ;)
PostPosted: Tue Feb 17, 2009 9:49 am
i should finally be picking up the engine in the next day or so ready to be dropped in at the weekend :)
it comes with 2L cams (which need to be fitted)
so do i need the sensors or anything like that from the 1.8/2L or will the 1.6 ones be fine?
PostPosted: Wed Mar 04, 2009 7:12 pm
ive got my 1.8 in the bay but struggling to get the spline and flywheel to mate together..
i think i may have made a school boy error (please tell me i havent lol)
i think its still got the 1.8 mondeo flywheel on the block, will this cause a prob? as i would rather not pul it out to have to change it over
PostPosted: Wed Mar 04, 2009 8:49 pm
You need to have the fiesta flywheel I'm afraid mate!!
The mondeo one is too big to fit in the fiesta gearbox!!
Sorry dude, looks like a change is needed.
Paul :halo:
PostPosted: Wed Mar 04, 2009 9:13 pm
it went in fine in the end, i just read somewhere that the 1.6 and 1.8 flywheels are the same unless its the 1.8 130 spec then thats the same size as the 2L
now ive just got the prob of 3 missing engine mount bolts lol
PostPosted: Fri Jul 10, 2009 9:14 pm
I have jsut fitted the 1.6 inlet maniflod onto a 2.0 and having running problems so far. Getting very hot and not idling well. Would people say that the change should include swapping the injectors - from the old black 1.6 ones to the beige ones from the 2.0??
Thanks
PostPosted: Thu Jan 07, 2010 4:29 pm
what sensors would you use from the 1.6si block tomake it compatable to the 1.8 silvertop ive just bought?
PostPosted: Sun Jan 10, 2010 8:46 pm
the crank angle sensor on the rear of the block that sees the fly wheel, thats the big one to make sure you sort out. but then depending on what flywheel! I would suggest you read the thread here on the swap to 2.0 as the majority is going to apply to you. I used the smaller oil filter no problems with the chassis
Fezzie Si 1.6 1995
