It is currently Sat Feb 23, 2019 6:31 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Thu Jan 04, 2007 11:44 am
Seems s this gets asked alot! ;)
Parts from the mondeo.
Engine- 2.0Ltr 16v zetec series one or 2 (Will say DOHC on series 1 and zetec 16v on series 2) Needs to be the silver top type not black top!
ECU - Either of the following ECu's will work:
DESK - 93BB-12A650-ED
DEWY - 93BB-12A650-EE
DEEP - 93BB-12A650-EF
MAF- Some say you need to match the MAF to the ECU but i presonally dont have a matching MAF and ECU and it works fine.
Throttle body
Injectors
Oil pump
- but only if you use the CVH oil filter
Parts to use from the fiesta (providing its a 16v zetec)
Loom
Inlet manifold- See N.B.
Exhaust Manifold- See N.B.
N.B. The Fiesta RS1800 would be better as there less restrictive than the 1.6 item.
Sump
Oil pick up pipe
Alternator
Starter motor
Flywheel
Dipstick tube
Power steering pump
Gearbox
Exhaust
TPS
throttle linkage and the cable retaining plate
- Throttle body items
Reccomended new parts to buy
Cambelt and tensioners
head gasket See N.B.
Exhaust manifold Gasket See N.B.
Inlet manifold Gasket See N.B.
Rocker cover Gasket See N.B.
Sump Gasket See N.B.
N.B. A gasket set can useually be purchased which will work out cheaper than buying individaully
Spark plugs
HT leads
Water pump
Oil filter - if your using the mondeo oil pump you will need a CVH item as its shorter!
Oil
Antifreeze/coolant
PostPosted: Thu Jan 04, 2007 12:17 pm
excellent matt, we needed something like this
i was thinking of doing somehting like this the other day, but never thought of posting it on fsi :look: , was going to be for mae and my scrap book 8-) :homo:
this should help alot of people 8-)
PostPosted: Thu Jan 04, 2007 1:20 pm
Should help people i hope, should also stop the forum becoming clogged with 2.0l parts questions! :)
PostPosted: Fri Jan 05, 2007 3:22 pm
thanks matt this helps alot cheers!! :)
PostPosted: Fri Jan 05, 2007 3:35 pm
no probs fella, happy to help! If you need anymore help just give any of the 2 crew( :homo: ) a shout! ;) :D :lol:
PostPosted: Fri Jan 05, 2007 9:38 pm
yeah we are always happy to help 8-)
PostPosted: Fri Jan 19, 2007 8:14 pm
Drives: Fiesta 2.0 Si
Hi just wondering cant you use the fiesta 16v ECU? If not is the 2.0 one just a plug and play item. Will i get injectors with the engine if i buy it from a scrapyard you think? Whats the part no's on the oil filters and whats best to have? Thanks scott. :look:
PostPosted: Fri Jan 19, 2007 11:01 pm
Maybe make this sticky?
PostPosted: Sat Jan 20, 2007 12:09 am
Useful Info cheers, hopefully possibility will be using in not tooo distant future
Breaking Standard Si
PostPosted: Sat Jan 20, 2007 1:24 pm
No! Wont run right!
yeah, just slap it on! :)
Most likely, but if not they are small enough to fit in your pocket if they try to charge you! ;) ;) ;) :lol:
Clarks.2007 wrote:
H Whats the part no's on the oil filters and whats best to have?
Next time i get one ill post them up, the best depends if you keep the mondeo oil pump or not! :)
its in FAQ's what more do you want! :lol:
PostPosted: Sat Jan 20, 2007 6:11 pm
What is N.B? lol sorry for the noob q's but??
Is MAF The mondeo air filter? cheers again. :P
PostPosted: Sat Jan 20, 2007 6:51 pm
N.B. means note below! :)
The MAF is the part after the air filter, MAF = Mass Air Flow sensor! :)
PostPosted: Sat Jan 27, 2007 8:54 pm
Right got myself the engine, MAF Sensor and injectors. (All other bits being used from fiesta 1.6 16v Si) Am i right in saying the CVH Oil filter wont fit because its too long? This means i will have to get a new oil pump? Im confused over the oil filter situation? lol :? :rolleyes: :oooh: :frown:
PostPosted: Sat Jan 27, 2007 9:05 pm
no you can't use the 2.0/1.6/1.8 oil filter as they are too long, you can use the 1.6 cvh iol filter with the 2.0 oil pump
PostPosted: Sat Jan 27, 2007 9:33 pm
Drives: V70 T5
this is becoming a FAQ in the FAQ section :lol:
CVH filter is the one to use unless you fancy changing oil pump for the 1.6 fiesta one.
PostPosted: Sat Jan 27, 2007 9:38 pm
:lol: :lol: :lol:
PostPosted: Tue Jan 30, 2007 10:18 am
What Clutch Would you advise? Any sites? Fast road one yes? lol :?
PostPosted: Tue Jan 30, 2007 10:20 am
Cant edit my post :( Also i wanted to know what you use is it the 1.6si Clutch or 2.0l? Im using the 1.6si Box
PostPosted: Tue Jan 30, 2007 10:28 am
i used my standard 1.6 clutch and is still going :lol: , other than that i can't really help :red:
yeah i noticed that aswell, you can't edit your posts :red:
PostPosted: Tue Jan 30, 2007 10:31 am
just noticed also.. you forgot sump gasket in your list matt :)
