It is currently Wed Jan 16, 2019 12:56 pm
PostPosted: Sat Aug 31, 2013 11:05 pm
Drives: 1600 SI
What Oil does everyone run?
I'm running 5w-30 fully synthetic on my 2.0 silver top Si. Is that good enough for it? It does run hot so I was worried about high temp protection. And also I'm running a Ram Air foam cam cover filter, could I be loosing oil vapour from that at all where its running hot and vented.
Thanks!
Admins please relocate as I know this isn't to do with cars lol.
'It's not a car, it's a daily project..'
PostPosted: Sun Sep 01, 2013 8:15 pm
5w30 is fine :)
How hot is the car running?
PostPosted: Mon Sep 02, 2013 8:56 am
Drives: 08 Ford Focus 2.0
i'd say semi synthetic - but it shouldn't really affect it running hot - like danny says - how hot is it?
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Mon Sep 02, 2013 9:39 am
I'm quite interested in this post and shall be watching to see everyones thoughts.
I current;y run Millers 5W-40 Nano tech as I thought I had cooked my Fully Synthetic 5W-30 on a spirited blast up the road one day before my pressure relief valve went.
I was seeing oil temps of 110 - 115 that day, not sure what Halford Fully Synth 5W-30 is good to so went Millers.
I'm tempted to change back to 5W-30 Fully Synth if it can take the temps of 110 or so as I regularly see that if I'm giving it a good pasting back up the dual carriageway as I do almost every other weekend.
Paul
PostPosted: Mon Sep 02, 2013 11:42 am
moved to the faq section for you :thumbsup:
PostPosted: Tue Sep 03, 2013 9:19 am
Drives: 2litre Si
I wouldn't say 110-115deg is excessive, silvertops seem to like high rather than low oil temp, I run 3-30 fully synthetic and oil temps regularly in region of 130deg with no problems before fitting the oil cooler, still can be in the region on 110-120 on a hot trackday, although can't remember even looking at the gauge on last one!
PostPosted: Tue Sep 03, 2013 10:13 pm
Drives: 1600 SI
Im using 5w-30 fully synthetic by Comma. Well it's running on the O on the norm, does rise when stood still and fan kicks in fine etc. it's sipping oil and was just wondering could oil vapour escape if its running that hot through a filter on the rocker cover? The 2.0 runs a lot hotter than my 1.6 before conversion.
PostPosted: Tue Sep 03, 2013 11:49 pm
That temp is fine. If you have a filter on the rocker cover crankcase breather, then yes it will leak through that. You need to either put it into the air filter or into a catch can
PostPosted: Wed Sep 04, 2013 9:44 pm
Drives: 1600 SI
Okay mate thanks. That's one less thing to worry about as its not long been done and its loosing oil. Anyone recommend a good 5w-30 oil?
