It is currently Thu Jul 19, 2018 12:43 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: 16's or 17's
PostPosted: Mon Mar 14, 2005 1:07 am
my si is currently on Tsw Hockenheim R's but there only 15's and look really poor, just wonderin if any arch mods are needed to fix 16's or even 17's. i can pick up a set of 16" cossie wheels for real cheap but i dont know if they'll rub even on really low profile like 35 or 40.
If In Doubt, Flat Out
PostPosted: Mon Mar 14, 2005 2:00 am
Drives: BMW E90 330D M Sport
i reckon its always worth getting your arch mods done, no matter what size wheels your running, opens you up to options in the future if you decide to change wheel sizes or lower the car further etc..........by the way go for 17's !
PostPosted: Mon Mar 14, 2005 2:42 am
Id disagree on 17s as Ive had them before
Just get 16s to be sure :D
I have a smooth sack mmmmmmm! cool beanz
PostPosted: Mon Mar 14, 2005 3:13 am
Why disagree on 17's ?
PostPosted: Mon Mar 14, 2005 9:45 am
Drives: V70 T5
stick with 15's, just get different wheels.
if they're done right it looks good
mine are 15's
PostPosted: Mon Mar 14, 2005 1:06 pm
how much arch work needs to be done if i was runnin 205/40/16's?
PostPosted: Mon Mar 14, 2005 1:38 pm
i just dont wanna buy some 16's and put them on the car for them to rub like fook and then have to get rid of them!
PostPosted: Mon Mar 14, 2005 1:59 pm
Drives: V70 T5
i think the only prob you may have with 16's is the supension cup.
try them with 195's not 205's and get a tyre with a very slanted sidewall
PostPosted: Mon Mar 14, 2005 4:49 pm
cossie wheels can be fitted but you have to completely butcher the arches or your car and run coilovers ask dr emmet brown on here about it :wink:
17's can and will fit but as said best doing arch mods if you can afford it anyway.
lowering your car further makes no difference on the size of your wheels unless they are physically tucked inside the arch.
what ever the wheel size it will still only go into the arch so far lowering just shortens the amount it will travel
PostPosted: Mon Mar 14, 2005 5:10 pm
how much you reckon it would be to do the arch work?
PostPosted: Mon Mar 14, 2005 5:21 pm
for what wheels?
for cossie rims you need the front arches cut right back on both wings, inner liners removed, arch kit if you have one modified and cut back, plus all the edges treated so they dont rust
on the rears you again need the arches cut back on both inner and outer skins then re-welded together plus the arch kit modified again if you have one.
and again all the egdes treated
for 17's and 16's normally you need the arches rolling on the rear and maybe trimmed or rolled on the front
arch rolling can cost anywhere between ?25 and ?75 per arch depending on how much you want it rolled by.
cutting you can do yourself for free and just touch the edges up either by spraying or using hammerite if hidden
be aware for cossie wheels you WILL need coilovers ?500+ for them
and you may need spacers on any size wheels depending on offset
if you have to use big spacers longer studs will be required these can be soucred from a mondeo other options include hub spacers which ill again require longer bolts
anything else just ask
PostPosted: Tue Mar 15, 2005 12:01 am
so for 16's i defo need arch work?
the wheels i'm lookin come with 195/45/16's, do you reckon i'd need to have 195/40/16's and just remove the inner plastic arch?
i know you can buy the tool that attaches to your hub and you can roll them yourself, but i'm poo at DIY and it always go wrong so i'd rather get them done pro or just leave the arches standard and hope that they dont rub!
PostPosted: Tue Mar 15, 2005 12:03 am
mine has 16's, is lowered and only get scrubs on full lock?
PostPosted: Tue Mar 15, 2005 12:08 am
wot about if you have ppl in the back?
wot tyres you runnin?
PostPosted: Tue Mar 15, 2005 12:09 am
havnt had ppl in the back yet (provisinal :cry: )
205/40/16 (i think)
PostPosted: Tue Mar 15, 2005 12:15 am
does it not rub over big bumps or jumps?
PostPosted: Tue Mar 15, 2005 12:16 am
jumps? :lol: not many of them round guildford mate
nah hasnt scrubbed on a speed bump yet mate
PostPosted: Tue Mar 15, 2005 12:20 am
right, so your runnin 205/40/16's with no arch work and its been lowered?
is it an Si, and did you change the suspension or just new springs?
PostPosted: Tue Mar 15, 2005 12:21 am
just crappy gmax springs mate. bloke before me did the work, but i cant see any arch trimming or any spacers. im not 100% on tyre size
PostPosted: Tue Mar 15, 2005 1:40 am
also every car is different there are lowered fiesta's on 17's with no arch work
there are cars on 15' with arch work you can turn round and say 100% it will fit
my advice will be to do the heaviest arch work you can
wel thats what i'm going to do
