It is currently Sun Jul 22, 2018 4:22 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Sep 18, 2009 10:31 pm
As i posted on the other thread, it is possible with the escort discs wih mondeo calipers and pads.
Get to a good motor factors and get escort discs which are the same distsnce front to back as the fiesta should be, but the bigger diameter, making 280mm i believe.
I was trying to use the mk2 mondeo front discs and calipers but the disc was too deep, and therefore rubs. The swap to a shallower disc sorts the problem out.
Fezzie Si 1.6 1995
PostPosted: Fri Sep 25, 2009 12:46 am
Drives: 2ltr Si
so what disc would i need to use the mk2 280mm mondeo ones?
cheers Grant
PostPosted: Fri Sep 25, 2009 8:03 am
Hi Grant,
I've been looking into this and I think that the EsCos discs are the ones we need as they are 280mm as standard but being Escort Mk5 they should have the correct offset for the Fiesta to run without spacers.
I'm sure someone will correct me if I'm wrong, but that's what I'm planning on getting!!
Paul :thumbsup:
PostPosted: Fri Sep 25, 2009 10:21 am
cheers Grant
You need discs which have the shallower "front to back" dimension. From memory below 44mm or so. The mondeo discs are deeper more like 49 and so the rubbing on the caliper. Escort discs are the way forward.....
Fezzie Si 1.6 1995
PostPosted: Sat Sep 26, 2009 1:01 am
Drives: 2ltr Si
ok guys cheers for that! i've already got a set of 300mm st170 discs but as im running 15inch rims they wont fit :( gutted they are massive lol
Grant
PostPosted: Tue Oct 06, 2009 4:49 pm
Drives: XR2i 2.3 Turbo
im confused everyone is saying 280mm, which is only the v6 mk2 or mk1 4x4.
The escort cos is also 280mm
standard 2.0 mondeo is 260mm
