It is currently Wed Aug 15, 2018 9:13 pm
PostPosted: Tue Sep 04, 2007 1:18 am
Drives: Fiesta Shed mk6
Hi all its been a long time waiting
Unfortunately the way it was the camera was no use, so i have no pictures but im hoping the guide can still be useful if u want a cheap brake upgrade and have a whole mondeo to do a whole upgrade
What you need:
Ratchet and sockets for 10,12 and 15mm
Angle grinding and grinding plate
Drill and 12mm drill piece
Brake Fluid
The First thing u had to do is take the front wheels off the car and so have the car on axle stands
Undo the caliper bolts 12mm (4) on the 2 front calipers
Remove the calipers and discs
Drill the caliper bolt holes with the 12mm drill piece
Using the grinder take about 3-4mm off the face of the hub at the caliper bolt holes
The caliper bolts will need trimming to fit and this can var between some brakes to make them perfect, but it is usually between 5-12mm mine had about 10mm taken off of them to give you a guide
After all of this fits together you can disconnect the brake hoses and attach them to the mondeo calipers
You will then need to bleed your brakes as normal
I hope that is of some use, sorry there were no pictures but thats how we did the brake conversion
Hope it helps :)
Ade
FACT wrote:
PostPosted: Tue Sep 04, 2007 1:18 pm
you used a grinder to grind down the face of it
dude.. you should have got that machined off!!
however well done on fitting the brakes... are they actualy any bigger than the fez ones? :lol:
PostPosted: Tue Sep 04, 2007 1:33 pm
pah nothing to it! :P it was grinding not slicing off ;)
But it al works jolly well and moe theyre the same size as cosworth brakes, 280mm front vented :)
They work fantastic nearly put me through the windscreen and no skidding, definately much better than the old 240mm si discs :)
PostPosted: Tue Sep 04, 2007 2:06 pm
when i bought my cossie brake pads, they said the mondeo ones were the same :look:
PostPosted: Tue Sep 04, 2007 10:23 pm
still, the faces are machined quite precicely from factory..
im sure that you would get some sort of odd pad wear if it was on the piss mabe?
let us know in a couple of months time ;)
PostPosted: Tue Sep 04, 2007 10:35 pm
didi the word grinder come in there :shock: :shock: holy shit as said would really need to be machined not just butchered with a grinder :lol: well we will see how it all copes further down the line
PostPosted: Wed Sep 05, 2007 8:23 am
good guide 8-) , some pic's would of been good tho :P
PostPosted: Wed Sep 05, 2007 10:50 am
Ta, having them machined would of been a better option true.
However id prefer a mechanic, a good eyesight and some measuring tools to keep it straight than machining them as its meant to be a cheaper way to fit not expensive ;)
hey ho
PostPosted: Wed Sep 05, 2007 9:41 pm
oh yeah i agree with you totaly DIY is alwas the cheaper option :)
not criticising dude.. just think there would have been a better way around it.. as it only costs like £25 to have a head skimmed
wouldent imagain it would be much for another flat face job 8-)
PostPosted: Sun Nov 18, 2007 2:06 am
Drives: MK1 Focus Estate Ghia
Me and my mates have done this to 3 Fiestas now, including mine.
Although all we did was drill them holes out to 12mm, and space the disk out 3mm, either cut the bolts down to stop them catching, or use a washer to space them out a little.
Job done, cost me £20 for better brakes. 8-)
PostPosted: Wed Jul 15, 2009 9:08 am
Just done this but forgot the - spacing the disc out thing - and have begun machining the calipers back by the discs themselves!!! Doh! So just 3mm of washers or something to bring the disc forward???
Fezzie Si 1.6 1995
PostPosted: Wed Jul 15, 2009 9:43 am
Yeah 3mm of something to bring the disc forward.
We've used a spacer cut up to fit behind the disc before, and washers.
PostPosted: Mon Jul 20, 2009 12:31 pm
Im in the process of getting a pair of 3mm plates laser cut to do the spacing, if anyone needs the same could get on the same machining job......
James
Fezzie Si 1.6 1995
PostPosted: Sun Aug 02, 2009 2:43 am
Drives: fiesta SI rs1800
what year mondy we talkin about?
PostPosted: Sun Aug 02, 2009 2:45 am
willl these fit under 15 inch alloys?
PostPosted: Sun Aug 02, 2009 12:08 pm
yeah got them under 15s on mine
PostPosted: Sun Aug 02, 2009 7:48 pm
is the calaper from a mk2?
PostPosted: Sun Aug 02, 2009 9:49 pm
Yep from Mk2 Mondy, All nicely sprayed up in black enamel too........... ;-( arrgh
Fezzie Si 1.6 1995
PostPosted: Wed Aug 05, 2009 10:16 pm
Drives: Suzuki Ignis Sport
aint it dangerous to use washers spacing things out?
and which bits u grinding off here? i didnt think u had to do that?
cant u use escos discs instead of mondy 1s, so no spacing required?
PostPosted: Fri Sep 18, 2009 7:50 pm
Drives: Fiesta ZS
What mondeo are we talking? And what is the item list? I've just found some
pads for a fiver.. I'm guessing there on the list of it's a mark three that is.
