It is currently Sun Jan 21, 2018 11:50 am
 Post subject: thermostat
PostPosted: Thu Jan 11, 2007 12:08 pm
Drives: Shitroen VTS
1, drain rad.
2. undo hoses to thermostat housing.
3. remove housing with a hammer (gaskets strong!)
4. prise out clip.
5. remove thermostat.
6. remove O ring.
7. clean housung.
8. attempt to fit O ring from your halfords thermostat, curse.
9. attempt to fit you halford thermostat, wondering why it wont sit level.
10. attempt to fit your halfords retaining clip, again cursing as it wont fit correctly.
11. say "fcuk it, it's not going anywhere"
12. having removed traces of first gasket, fit up new one in place, wondering if a blind man designed it because NONE of the holes line up.
13, put it all back together, fill system, watch needle settle at the "M" whilst vowing to only buy motorcraft parts in future.
hope this guide is useful. :)
PostPosted: Thu Jan 11, 2007 12:20 pm
good one mate.. end of it made me chuckle :lol:
get some pics to go with it if you can 8-)
PostPosted: Thu Jan 11, 2007 12:25 pm
Drives: V70 T5
i'm assuming this is for 2i engine
PostPosted: Thu Jan 11, 2007 12:33 pm
yeah, im sure it aint that different for the zetec apart from some pressure valve or something. :)
PostPosted: Mon Feb 26, 2007 4:29 pm
i design the halfords gaskets, so blame the one eyed, deaf, illiterate, dense git that is me
only jokin but i do know the bloke who does
PostPosted: Thu Mar 15, 2007 5:48 pm
Drives: V70 T5
pressure valve?
it is fairly straight forward on the zetec. drain coolant, remove hose undo three front housing bolts, change 'stat, refit, add coolant
