It is currently Wed Oct 21, 2020 7:24 pm
PostPosted: Tue Oct 03, 2006 1:09 pm
This is how i fitted mine.
The bits i used,
Laguna splitter! :) :rolleyes:
4 x nuts and bolts
4 x rivets
2 x 90* bracket
1 x flat bracket
1 x can of hammarite
Tools i used;
Drill + drill bit
Riveter
Alan keys
Spanner
Tiger seal with gun
Bradal
Jack and axle stands
1. I started of by holding the splitter under the bumper and masking taping it on, so that you can mark it and cut down to size, at this point i relised that the towing i sat lower than my bumper slightly so i cut a section out to accomodate this.
2. As you look at the splitter there are a number of little tags sticking out in each of these i drilled a hole big enough to fit my bolts through.
3. I then jacked up the car and placed axle stands under, i then taped the splitter back in place and marked underneath with caulk where the holes i had drilled before had metal from the valance to drill into to attach the splitter to,i then drilled the holes and sprayed the newly drilled metal with hammarite as rust needs no incouragement on a ford! i found that near the towing eye there was no metal to drill into, so i got a flat bracket and attached that.
Rough postion of flat bracket
4. I then riveted the bracket to the car and to the splitter, i then went around and attached the splitter using the holes i had drilled.
5. On the corners i found they stuck out a bit,
so i bought some 90* brackets and if you look under your bumper there is a slight gap between the metal and the bumper.
i then lined up the bracket on the outside and used the bradal to mark where i would drill, then drilled!
I then took the bracket and lined the upright part of the bracket with the splitter end and marked with the bradal and drilled again.
I then riveted the bracket to the splitter FIRST
I pushed the bracket into the gap between the bumper and metal and lined the holes up and rivited this.
To make sure the splitter stays i went round with tiger seal.
And hay presto you have a splitter!
Hope this helps! any problems just give me a shout! :)
Ps excuse my rust :lol: :cry:
PostPosted: Tue Oct 03, 2006 2:01 pm
Drives: Nissan Pulsar GTi-R
Good guide :wink:
PostPosted: Tue Oct 03, 2006 4:09 pm
EvilDes wrote:
Good guide :wink:
:D why thank you! 8-)
PostPosted: Tue Oct 03, 2006 4:55 pm
nice guide mattyboy 8-)
PostPosted: Tue Jun 05, 2007 5:54 pm
The Nude Numpty
The Nude Numpty
yea nice guide, just fitted one of them onto my Si,
chhheeers
PostPosted: Tue Jun 05, 2007 7:56 pm
Drives: Like a boss
how do you fix it actually to the bumper instead of the valance???
PostPosted: Wed Jun 06, 2007 9:47 am
You can't really as theres not a flat surface to attach it to, you could try using loads of tigerseal but dont expect miracles!
PostPosted: Fri Sep 14, 2007 3:44 pm
could you spray it car colour to make it blend in more! or are you supposed to leave it looking dull?
http://i7.photobucket.com/albums/y287/j ... paint1.jpg
PostPosted: Fri Sep 14, 2007 3:50 pm
You could spray it or you could just use some back to black or bumper and trim care to make it shine! :)
PostPosted: Thu Apr 07, 2011 1:25 am
Drives: Rs1800
is there a guide how to fit the vr6 splitter to a rs bumper :thumbsup:
The Loumiester wrote:
Nothing wrong with bigging up your own car, thats why you own it.
