It is currently Wed Oct 21, 2020 7:20 pm
PostPosted: Wed Oct 12, 2011 1:36 pm
After searching around, googling, and only finding "1mm toe in" concerning the front suspension angles, I decided to get the information from the horses mouth. This guy had to dig out an 8 year old obsolete manual to find these!
All fiesta MK3's:
Front 2 degrees negative +/- 1 degree
Rear 2.3 degrees negative +/- 2 degrees
Camber angles
Standard fiesta 0.9 degrees +/- 1.2 degrees
XR2i/RS1800 1.1 degrees +/- 1.2 degrees
RS Turbo 1.4 degrees +/- 1.2 degrees
Hope this helps anyone doing their own measurements and adjustments.
Once I get onto the computer later I'll convert these into alloy rim sizes and mm's.
PostPosted: Fri Oct 21, 2011 2:47 pm
Drives: MK1 Focus Estate Ghia
So... Si camber would be 1.1 - 1.2 degrees?
PostPosted: Fri Oct 21, 2011 2:57 pm
Yeah. This highlights the different wishbones for the RST. I got the camber angles for the people who have adjustable wishbones.
PostPosted: Fri Oct 21, 2011 3:05 pm
Nice one cheers
I'm glad I found it as I was going to have a look for the camber myself... just incase the garage didnt know for when they set up my adjustables.
