It is currently Wed Jun 20, 2018 7:01 am
PostPosted: Fri Mar 19, 2010 8:35 pm
Drives: Suzuki Ignis Sport
alrite guys just found these:
http://www.pumaspeed.co.uk/showdetails. ... ductID=238
they are 4 a ka but bound to fit a fiesta and will come in handy for those of you like me who are running mondeo v6 brakes
PostPosted: Mon Mar 22, 2010 8:45 am
Drives: ST24, 2L ACCORD VTEC
anyone buying mondy v6 brakes bare in mind that ford used normal 2 litre brakes on late mk2's v6's and these are smaller than the v6 brakes
PM if u want u advert here :D
PostPosted: Thu Jul 08, 2010 2:53 am
Drives: Fiesta Si 1.6
Sorry to sound stupid but i'm confused :? what does this mean? I've seen in the other v6 feed that when changing the brakes to v6 you should put in braided lines but again im still totally confused. does this mean that the lines from the si wont fit the v6 brakes or vice versa. In fact could you tell me what is best to use as I have found a brake set that comes with discs, pads, calipers, carriers and the 12mm bolts, and a fiesta si to stick them on.
I know what you are thinking... this lad shouldnt be allowed out alone let alone be allowed to mess around with a car but i am trying to learn :sigh:
PostPosted: Thu Jul 08, 2010 7:09 am
dont know about braided lines or that but what im refering to is, early v6's used "real" v6 calipers, from about 1999 the v6's started getting standard 2litre calipers fitted, 2litre calipers are as you would expect smaller than the v6 caliper.
PostPosted: Thu Jul 08, 2010 7:36 am
you need the early ones then they got bigger discs and calipers. just to simplify it. :D
PostPosted: Thu Jul 08, 2010 3:33 pm
So are the mk2 v6 brake calipers the proper v6 or will that have changed to the 2lt calipers. Dont the mk3 and later mondeo brakse use 300mm discs and the pre mk3 use 280mm discs, how come the calipers are smaller?
PostPosted: Sun Aug 29, 2010 4:28 pm
Drives: Fiesta 1.4 cvh
Mk1 and early mk2 mondeos have the bigger v6 calipers, the late mk2 have the 2litre calipers, instead of using the pumaspeed disc spacers i cppied them an made some out of 3mm thick brass plate, cost about £20 or you could just use escort cosworth or sierra 4x4 cosworth discs
PostPosted: Mon Aug 30, 2010 1:24 am
well in the end i bought the St150 set up, just waiting to fit them now as i had had some issues lol
