It is currently Tue Jul 17, 2018 11:05 am
PostPosted: Wed Jul 08, 2009 1:15 pm
Does anyone have or can tell me where I can find a guide for fitting carbs or throttle bodies?
Cheers
PostPosted: Wed Jul 08, 2009 8:01 pm
havent got a guide or anything but i have put webbers on mine and it suprisingly simple to put the carbs on i didnt do the wiring for them but that seems easy enough aswell any questions just ask :thumbsup:
PostPosted: Wed Jul 08, 2009 10:29 pm
Drives: 2litre Si
Cheers
as above what sort of thing are you thinking of doing? think a few have done it. ive fitted gsxr throttle bodies with the standard ford ECU on a 2litre zetec and motorbike carbs on a 1600CVH.
some info here
http://www.linktobusiness.co.uk/forums/viewtopic.php?f=16&t=1960
post any questions
PostPosted: Thu Jul 09, 2009 8:40 am
Will, I am looking at fitting motorbike bodies to a 1600 si and later to a Mondeo 2.0 when I swop the engines over. I have only had a quick glance at the guide but it looks impressive.
Questions so far:
Did you use the original fuel rail and injectors?
I was under the impression that you had to use an aftermarket ECU, what ECU have you used, DESK?
Which fuel regulator did you use?
What air filters did you go for?
I'm sure I will have many more questions as I can have a bit of a brain block :|
PostPosted: Thu Jul 09, 2009 1:05 pm
Drives: 2litre Si
have a look at my thread below (will get round to doing a guide) for a bit more insight into how ive done it, it works for me and now at 150bhp. but in the usual get out clause way it worked for my but cant guarentee it!
http://www.fiesta-si.com/forums/viewtopic.php?f=5&t=13734&hilit=throttle+bodies
Answers to Questions so far:
Yes
no used the standard ECU with all sensors and MAF @150bhp, if you want to run without the MAF think this is when you will need aftermarket ECU. But with the setup i currently have with a aftermarket ECU should expect to see 160bhp plus but thats £750 for 10bhp more
standard one on the end of the fuel rail
cone filter as used the standard MAF as pictures
there are lots of other ways in achieving the same goal, the individual throttle bodies added about 10bhp and alowed it to rev a lot higher as RR graphs show, wether you would see any great gains on a 1.6 as if the throttle body is a restriction, could just replace with larger 1.8 one.
PostPosted: Fri Jul 10, 2009 8:33 am
Will, as you used the original fuel rail and injectors, I'm guessing that you used the original manifold? If you did, did you have to do any modifications?
PostPosted: Fri Jul 10, 2009 8:58 pm
you can use the oringnal exhaust manifold but need a inlet well i did for the webbers
PostPosted: Fri Jul 10, 2009 10:54 pm
Drives: 2litre Si
the injectors are in a separate sandwich plate to the manifold which i reused and made a new manifold which connected to this with the throttle bodies will add more photos to explain better in morning.
picture of the manifold and separate injector sandwich plate
i reused the sandwich plate and made my own manifold to attach the throttle bodies
and then a plenum chamber made out of fibreglass
but ive seen pictures where others have used the orignal sandwich plate and cut down the inlet manifold about 50mm up to just the individual tubes are left and mounted the throttle bodies with hose to this as shown in this thread. (im sure ther are more pictures on here somewhere)
http://www.fiesta-si.com/forums/viewtopic.php?f=10&t=13439
