It is currently Sun Jul 22, 2018 12:31 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jul 01, 2009 5:44 pm
Drives: fiesta SI rs1800
the speedo wire from gearbox
PostPosted: Wed Jul 01, 2009 10:43 pm
Drives: MK1 Focus Estate Ghia
Could be brown yellow.
Just try each one, you'll soon know if your speedo doesnt work
PostPosted: Tue Sep 29, 2009 12:05 am
i know this is an old thread now but i did a full guide on this here
http://www.fiestaguides.co.uk/content/mk5_clocks.html
pic fitted as well
my air bag light is in a diff place, but if you earth the ire the light will go off
as for fuel guage, i've tried a few circuits and nothing yet
ANdy
PostPosted: Wed Sep 30, 2009 11:04 am
For the fuel gauge fitting the Zetec-s fuel sender obviously works done this to fix my mk3 Mondeo clocks fuel gauge reading backwards :)
PostPosted: Sun Oct 04, 2009 12:16 am
how hard is it to fit the new sender?
PostPosted: Mon Oct 05, 2009 2:21 pm
The hard part is getting the fuel tank down and out as the clips/bolts are often rusted to bits lol the sender on mine i cut the zetec s mounting and welded it on the my pump assembly but on my mates we screwed it together as he doesnt have a welder. You might able to use the whole zetec s assembly and pump but i cant remeber with out looking at them both again basically with a little effort its quite an easy job especially if like me your uprating your fuel pump at the same time :)
PostPosted: Mon Oct 12, 2009 10:14 pm
is this te same for escort mk6 dials??
PostPosted: Sat Dec 19, 2009 6:49 pm
Drives: Si 1.6 & ST170
has anyone got them working properly yet? iv seen some dials on ebay cheap enough but will i need anything else as it says get as much wiring as possible.
The Loumiester wrote:
PostPosted: Sat Dec 19, 2009 7:04 pm
yh i have wiered them up and there ok i have the fiesta mk4 ones though not the digital ones
PostPosted: Sat Dec 19, 2009 7:06 pm
are the mk4's easyer to get to work?
PostPosted: Sat Dec 19, 2009 7:12 pm
there the same apart from what i have herd the digital ones the fuel gauge is reversed ...when urr tank is full it will say empty ....
PostPosted: Sat Dec 19, 2009 7:20 pm
so the mk4's are a better choice lol
PostPosted: Sat Dec 19, 2009 7:36 pm
if u dont mind not havin a digital mileomiter yh mine work well i thinks its good
PostPosted: Sun Feb 21, 2010 11:07 pm
Drives: Land Rover Discovery
Just a bit of an update....you don't have to bother running a wire to the VSS for the speedo readout, go to pin 3 on the ECU which should be brown/white....easiest route for it that I found was to run it past the vents etc, down into the passenger side footwell, then disconnect the ECU from under the bonnet and feed a draw wire through from the engine side, and drag your wire through....works a treat :)
I took my +12v permanent feed from the clock, as I do believe that's on the same (15a?) circuit as the interior light/radio/cig lighter, and it was a nice short run....
In the process of murdering my second Si :'(
