It is currently Tue Sep 25, 2018 3:58 am
Post new topic Reply to topic  [ 170 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Thu Oct 26, 2006 4:54 pm
lucasdemoley wrote:
My 2.0 si is going on the rollers this saturday, i'll post up the results.
Whats Mods have you done to it!
Good luck, was pooing myself before i took mine on, was expecting it to go bang on the rollers, but the guy there just said its puts no more strain on ya engine then normal everyday driving! :)
PostPosted: Fri Oct 27, 2006 9:07 am
keep us updated, as matt said what mods have you done to yours :?
where about are you getting your rolling roaded? and how much is it cost you(if you doont mind me asking)
PostPosted: Fri Oct 27, 2006 9:38 am
Erm, not sure where im having it done, south wales some where! I'm meeting a group of boys from a south wales car club in carmarthen (i live further north) and then heading with them to the place. I think cos there should be a fair few of us its only costing like £25 or something, which aint bad! Gona cost me more than that in fuel to get down there!
As for mods, not much really. Just the 2.0 conversion running with the 1.6 si inlet manifold, performance air filter, although i'm still using parts of the 1.6 air ducting, so this might prove restrictive. Its also got a different backbox, but doubt that will make much difference! I also dont have the egr.
Not really hoping for much, say 130, its more to see when the power starts to come in ect, and just to see if there are any problem spots, as after 5k it feels like it drops off a bit, not sure if its a fuel pump problem, so hopefuly this will pick up problems like that.
PostPosted: Fri Oct 27, 2006 9:47 am
My peaks at 5k so thats probley whats happening with yours! You should get 130+, i got 131 but it was being restricted by the ERST crossover, so unless you have one of them you should get more!
Good luck! 8-)
PostPosted: Fri Oct 27, 2006 10:43 am
so with the RS1800 inlet on i should see quite close to the standard 2.0 power then :? , i still have my 1.6 air box and inlet pipe i am sure this must be quite restrictive :look: , i still have my egr
for a group £25 isn't bad 8-)
PostPosted: Fri Oct 27, 2006 10:52 am
you could have a bit more around the 140 mark maybe! do you have an aftermarket panel filter terry? :)
And ive still got my EGR as well! :cry:
PostPosted: Fri Oct 27, 2006 11:09 am
nope i still have a standard panel filter :cry:, i need to buy a proper reducer pipe for my MAF as its bodged on at the moment :look: :cry:
PostPosted: Fri Oct 27, 2006 11:18 am
if you get an aftermarket panel filter you'll be able to release a few more ponys! ;)
PostPosted: Fri Oct 27, 2006 11:35 am
more ponies :insanity: , i want to get a K&N but i am worried about heat soak :cry:
PostPosted: Fri Oct 27, 2006 11:40 am
then keep the airbox and use a K&N panel filter! :) less heat soak and some even say you get more gains from them! 8-)
PostPosted: Fri Oct 27, 2006 11:54 am
yeah i have also heard that there are some gains to using a panel filter, might modify mine a tad tho :look:
PostPosted: Fri Oct 27, 2006 1:00 pm
Put ya car on the rollers as it is now, then with a after market panel filter then with a induction kit! Then we can see if the rummers are true! :) ;)
PostPosted: Fri Oct 27, 2006 1:31 pm
thats a good idea 8-)
PostPosted: Sat Oct 28, 2006 9:46 pm
ok. My car made 129.5 bhp and 172 flb of torque. There was a bit of a problem with back pressure at the top end, and it only reved to 5600 rpm which isnt that much really! There is a constant power increase though up to about 5400rpm, and its a smoooth curv. So a new zorst system should sort the problem and give me a few more ponys!
PostPosted: Sat Oct 28, 2006 9:55 pm
excellent result 8-) , very impressive torque figure 8-)
i hope mine performs that well :look:
PostPosted: Sat Oct 28, 2006 10:42 pm
just incase you end up going and paying top dollar for a dyno test.. have a look for a local college with a dyno.. usually do a full hour test or whatever for about 20 quid.. do as many as you like sorta thing.. we have one near us in warwick very good!
PostPosted: Sat Oct 28, 2006 10:47 pm
really i never knew that, cheers for the tip paul 8-)
PostPosted: Sat Oct 28, 2006 11:08 pm
This cost £20 in the end, and the bloke was well clued up, helping people out with any problems ect, top bloke. Power at the wheels was 100bhp, which wasnt bad really. My lights are on cos he couldnt get a rev reading as my batery was fullly charged so the alt wasnt giving it any power, if that makes sence!
PostPosted: Sat Oct 28, 2006 11:21 pm
nice video,
what mod have you done to your 2.0 again :?
PostPosted: Sat Oct 28, 2006 11:32 pm
not much,
Egr removed,
Performance induction air filter thing
OIl filter breather
its using the 1.6 16v inlet manifold, and some of the 1.6 ducting, so probs quite restrictive
And a 5" back box that has been squished so is now something like 5" x 2.5" rectangle or summin. This came off my 1.1 fiesta, and i think that the the bit to make it fit to my si was simply welded on, so i have a 1.5" (or whatever the diamiter of a 1.1 exhaust pipe is) restriction going into my backbox, which could be the cause of the backpressure problem.
I'm going to look into bike bodys, zorst sytem ect after chrismas, depending on uni and funds.
