It is currently Mon Feb 18, 2019 2:43 am
Post new topic Reply to topic  [ 170 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
 Post subject: Re: 2.0 zetec into FSI
PostPosted: Sun Jul 25, 2010 8:02 pm
Can the Mondeo gearbox not go on for any particular reason? If it's a space reason, what space?
PostPosted: Sun Jul 25, 2010 8:34 pm
Drives: Si 1.6 & ST170
as far as i know it just wont fit . . .
The Loumiester wrote:
PostPosted: Mon Jul 26, 2010 9:13 am
as lou said it wont fit! it can be made to fit, but you'll need custom mounts and i think you'd then need to look into custom driveshaft lengths
if you have the money go for it, if not i'd stick with the Si/RS1800/FRST/XR2i/S2 boxes
PostPosted: Mon Jul 26, 2010 9:47 am
I was just thinking about a 6 speed possibility, shorter ratios to bring the top down but have a better top cruising gear for long journeys, resulting in better fuel usage.
So there's nothing getting in the way physically, just mounting it, and shortening the shaft(s) to accomodate the extra width then.
PostPosted: Mon Jul 26, 2010 9:58 am
Are PATS gonna be an issue when swapping the engine? how do you tackle it all?
PostPosted: Mon Jul 26, 2010 10:16 am
not really know, if your good with a welder then your away, you'd just need to get hold of a firm to sort out the shafts
i would of loved a 6 speeder in my Si :chill: :D
PostPosted: Mon Mar 28, 2011 9:16 pm
Drives: 1.6si
The big one to watch out for that I missed is the Crank Angle Sensor which is fixed to an alloy housing which is bolted to the rear of the block. Because I used a Mondeo Automatic the sensor is fixed at a larger diameter than the sensor holes in the 1.6 flywheel I used. I didn?t realise this until I came to start the engine and had no spark or fuel. The solution was to change this alloy housing to correctly re-position the sensor. The bad news was that I had to remove the gearbox again to change this!!!!!
Crank Angle Sensor Mounting Block?Beware!!!
Does anybody have any more info on this??? I dont fully understand it :( Thanks guys
THE DON..... DON DIGGLER
PostPosted: Thu Apr 14, 2011 7:08 pm
Drives: Fiesta 1.4 cvh
the crank sensor has to line up with the trigger slots on the back of the flywheel, so if u have a automatic sensor housing with a 1.6 flywheel from a manual, then the sensor wont pick up a signal, therefor no spark, best thing to do is to keep the sensor housing matched to the flywheel that came from the same car if you can
With the mondeo box also, most of them have a hydraulic clutch slave cylinder inside the box, if you were to go through with it and fit a mondy box then you would need to custom make a pedal box with an inbuilt clutch master cylinder, plus a clutch/brake fluid feed from the brake fluid resivior snd all other connecting lines, alot of work when there are much better gearboxes to use with much less hassle of fitting them
PostPosted: Tue Jul 05, 2011 11:12 pm
Still tempting to do it, lol. I'm up for ripping the stuff out of a mondeo and a scrapped fiesta, comparing, sizing up etc. I've got the entire braking system off a mondeo on my car, why not do the gearbox as well as the engine? :P
PostPosted: Thu Jul 14, 2011 12:19 pm
good on you if you do it, but the ratios are quite lazy tbh, st170 6speed box would be a much better choice
Users browsing this forum: Google [Bot] and 4 guests
