It is currently Mon Jun 18, 2018 5:02 am
 Post subject: clutch adjustment
PostPosted: Wed Apr 23, 2008 11:39 am
Drives: fiesta si
rite ok this puzzeled the fuck out of me so i cant be alone but i have now worked out a way to do it piece of piss
fit new cable on gearbox and on pedal then with pedal up in the air undo the white screw thing 4-5 turns then gently tap it (the white screw) with hammer screw diver ect dont need to do it hard or if ur like me and double ard u can push it in with ur thumb . and it will click and drop down either do this until it is where u want it or do it till its on the floor and pull it up to where u want it ( it will click when u pull it up cuz its ratcheting up the meck) then do up screw and bobs ur aunt and fannys ur cousin
hope this helps sum1
thanks
 Post subject: Re: clutch adjustment
PostPosted: Wed Apr 23, 2008 9:26 pm
good guide there 8-)
should hopefully help people out
PostPosted: Wed May 14, 2008 10:59 am
I dont have a white screw, is there anything you can do with an automatic adjustment clutch pedal/cable?
PostPosted: Wed May 14, 2008 7:01 pm
Drives: fiesta si
not sure sorry
PostPosted: Thu Oct 16, 2008 7:04 pm
Drives: MR2 TBar
had to change mine today :frown: pedal needs some sort of adjustment but i cant see a white screw anywhere :?
PostPosted: Fri Oct 31, 2008 12:35 pm
Ive just tried adjusting mine and ive unscrewed the little screw - well the white bit turns not the screw bit on the inside, tried pushing it in, hitting it, and it doesnt want to budge! lol
PostPosted: Sun Nov 02, 2008 1:25 am
Drives: Audi A4 Cabrio v6
it will budge, can be stiff at first, try givin the pedal a gentle push or pull when u try and push the screw in :) , the white screw just needs to be undone enoth for it to be pushed in enoth to click it off the rachet, just make sure u dont wind it all the way off otherwise u may be in trouble :lol:
