Fiesta-Si.com • View topic - lowsi's guide to fitting ST150 calipers and discs to your si
It is currently Sat May 25, 2019 10:23 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 25, 2008 11:07 pm
iv seen rear brakes for the MK3 u reacon you could just use front brakes and puting them on the rear??
PostPosted: Thu Jun 26, 2008 9:49 pm
definately buy sum of them in the future
PostPosted: Fri Jun 27, 2008 9:03 pm
PostPosted: Thu Jul 10, 2008 1:36 pm
I might have to invest some money in the future on these! Do you think they would fit the normal mk3.5 fiesta? I presume they would as its pretty much the same car lol.
PostPosted: Fri Jul 11, 2008 12:10 pm
the reason you cant put them on the back is that on the fiesta the drum and hub are one piece... thus you take the drum off you have nothing to attach the disc to. you can use 130 spec escort mk5 stuff..fiesta centre do a kit that uses sierra bits and supplies 2 hubs for use with the kit...orrr you can if you fancy some more work. the focus setup can be made to fit the std beam with work but will also bolt to right onto a ZS beam. however beware your master cylinder will probs poo its pants if you put discs on the back with bigger stuff on the front.
brakes will fit mk3 and 3.5 the same..all they did was decide to put a smaller head (same thread on the bolts) on the later ones otherwise all good ;)
Jam
PostPosted: Mon Jul 14, 2008 2:51 pm
wa size discs are these???
PostPosted: Mon Jul 14, 2008 6:40 pm
PostPosted: Tue Jul 15, 2008 12:34 pm
bigger than rs2000 ones then? i think they are 260mm
PostPosted: Thu Jun 25, 2009 8:44 am
are they 15 rims inn the picS?
PostPosted: Thu Jun 25, 2009 8:58 am
good guide lowsi.
hmmm Bognor Regis.....i spent all my summers there as a kid @ Middleton-on-sea with my nan :thumbsup:
PostPosted: Thu Jun 25, 2009 9:36 am
PostPosted: Fri Jul 10, 2009 7:19 pm
wat brake hoses do u have to use for these? si 1s?
PostPosted: Thu Dec 31, 2009 10:01 pm
did you keep the si servo and master cylinder?
I Want these brakes, can seem to find an st150 scraped anywhere though, what brakes will a normal mk6 fez have?
I WANTS BOOST!
PostPosted: Tue Jan 12, 2010 5:39 pm
PostPosted: Fri Apr 09, 2010 5:48 pm
will the callipers bolt straight into the brake line on the car as it is.
PostPosted: Tue Jun 15, 2010 2:19 pm
Onslack's other half
will the standard master cylinder cope ok with uprated fronts?
PostPosted: Tue Jun 15, 2010 3:31 pm
yup will be fine :D
some people are upgrading to MK1 mondeo ones now, sure there's a guide about on how to do it, i'll have a look and see what i can find :thumbsup:
my bad i found a guide for fitting a MK1 mondeo servo
http://www.fiestaguides.co.uk/content/m ... inder.html
Users browsing this forum: Exabot [Bot] and 2 guests
