It is currently Sun Feb 25, 2018 4:47 am
PostPosted: Thu May 05, 2005 4:11 pm
has anyone got any images of them putting rs2000 side skirts on their car? and where they drilled etc.
PostPosted: Fri May 06, 2005 5:13 pm
or does anyone know how to fit them?
was it easy?
did you do them yourself, spray too?
PostPosted: Fri May 06, 2005 10:36 pm
Check out my pictures...easy to do...took about an hour from start to finish!!!! Apoxy resin and screws!!
http://fiesta-si.com/forum/viewtopic.php?t=571
PostPosted: Fri May 06, 2005 10:46 pm
that easy! cheers mate. was it just a screw either side? did you drill into the bodywork first.
and what kinda size screws
PostPosted: Mon May 09, 2005 12:14 pm
epoxy resin not APOXY L99, use stainless self tapers as there will be no rusting, matis end by arches, also coat paint work under skirts with waxoyl to stop corrosion. PROPER JOB !!
PostPosted: Mon May 09, 2005 6:10 pm
PROPER JOB!!!!!!
PostPosted: Mon May 09, 2005 8:28 pm
PROPER JOB!!!!
nice one mate cheers for the feed back.
let us know what the car looks like on the gallery when done.
