It is currently Thu Apr 26, 2018 6:31 am
 Post subject: 1.8 maf on 1.6 si
PostPosted: Sat Apr 30, 2005 9:35 pm
just got a 1.8 maf sencer put it on earlyer with it pluged in wouldnt run but unplug it runs fine should there be power increase thoe. will the engine get damaged with the 1.8 maf and it being unplugged
if aint low enough cut the springs sorted
PostPosted: Sun May 01, 2005 1:11 am
Drives: V70 T5
is it off the gti or xr3i 130? if not then it's the same as the 1.6. it should work plugged in.
PostPosted: Tue May 03, 2005 3:23 pm
shouldn't run without and the 2.0, GTi, or 130ps XR, RS1800 mafs will make a little bit of difference but nothing you'll really notice
PostPosted: Tue May 03, 2005 4:39 pm
Drives: V70 T5
they should run without it plugged in, but it'll be in 'limp home mode'
any of the larger MAF's will not work correctly with the 1.6 (guru) ECU. plug it in, and if it doesnt die, then it'll run really poor bottom end, but above 4k rpm it seems ok.
i dont know if it would work right with the throttle body too though. might make it even up a bit
 Post subject: maf
PostPosted: Tue May 03, 2005 7:45 pm
maf woz off a 1.8 mondeo didnt really notice anything just a bit louder only worked with it unplugged running well rich poping and banging off accelraction. even swaped the 1.6 sencer over to it still run crap big flat spot.just wanted a bit more power would a induction kit give any power and a loud roar if yer which induction kit is the loudest?.or would a panel filter with a drilled air box with a cold feed going in to the box be louder and better power
 Post subject: Re: maf
PostPosted: Tue May 03, 2005 7:52 pm
Drives: V70 T5
about 3.5k rpm? sounds similar to mine when i had it plugged in. unplugged it and it ran ok ish, still seemed a bit poor low down though. i've put the 1.6 one back on now, until i get a 2ltr MAF too.
PostPosted: Tue May 03, 2005 11:57 pm
sorry meant you shouldn't run without the maf sensor.
an adjustab;e fuel pressure regulator would sort out the flat spot though
PostPosted: Wed May 04, 2005 12:07 am
Drives: V70 T5
i was thinking that, but that means spending money, might just put jubilee clip round fuel return, lol.
jj
Users browsing this forum: Bing [Bot] and 13 guests
