It is currently Fri Jul 20, 2018 11:30 am
PostPosted: Sun Apr 17, 2005 11:51 am
hi people just wondering if u can take the hole maf sencer housing off and fit a universal cone filter to the small rubber pipe in front of it.will the engine run properly dont want it to run lean.
if aint low enough cut the springs sorted
PostPosted: Sun Apr 17, 2005 4:45 pm
would then be right on top of the engine mate, v hot air i should think, no idea if it can be done tho soz
PostPosted: Sun Apr 17, 2005 6:56 pm
Drives: 170bhp RS
cant say iv ever tried it to be honest. it'll run without the MAF sensor, but ill guess its there for a reason :)
think he meant skip the maf, traser, not the hole induction pipe :lol:
PostPosted: Sun Apr 17, 2005 11:20 pm
:rolleyes: :lol: sorry mate!!!
PostPosted: Mon Apr 18, 2005 12:07 pm
Drives: V70 T5
yes you can take it off if need be, but the ecu will run with one sensor less.
but, why dont you just buy a proper K&N or the car?
PostPosted: Mon Apr 18, 2005 1:34 pm
yes you can take it off but i wouldn't advise it the MAF (mass air flow) sensor is there for a reason. it measures the airfloe and your ecu will adjust the fueling accordingly
so basically without running the MAF your fueling will be shot
it will either run rich. not the end of the world but you'll be looking at stupid fuel consumption, having the constant smell of petrol in your car and when you start it up it'll prob flood cos as the choke is on it will be pouring way to much fuel into your engine
or it'll run lean, in which case you'll suffer from detonation and if you dont catch it in time you'll eat headgasket at best and be in for total engine rebuild at worse.
which even if you then go 2.0 works out at around ?500-?1000 for putting on an airfilter.
your call mate but your engine will get damaged if you dont run it
Tony :D
