It is currently Thu Jan 17, 2019 10:29 pm
PostPosted: Tue Feb 05, 2013 12:07 am
I am putting a 2.0 silvertop into a mk3 Fiesta Si, I want to use an ib5 box but don't know which one to go for.
My first thought was an Escort RS Turbo series 1 or 2 to get an LSD, but apparently the ratios may be too tall.
There seem to be quite a choice of boxes as follows:
1. The standard 1.6 already fitted to the Fiesta
2. 1.8 Fiesta Diesel
3. Ka
5. Puma racing (probably too expensive)
No doubt a number of others I'm not aware of.
I want some close ratios for good acceleration plus a tall 5th gear for more relaxed motorway driving.
I know that ideally the LS diff should be fitted to whichever box is used, and I could get one of these from an RS Turbo box, I don't know if the S1 or S2 would be the more suitable LSD donor?
In any event I don't feel particularly confident in trying to fit the diff as I have never stripped a gearbox before!
All advice greatly appreciated!
PostPosted: Tue Feb 05, 2013 9:25 am
Drives: 08 Ford Focus 2.0
the standard box, diesel box and RST boxes are BC boxes not IB5
S2 ERST Box with LSD would do you good!
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Tue Feb 05, 2013 4:13 pm
if you can get a Erst box id go for that !
i found the ratio's spot on when i had one in my 2.0'd mk2 fez :thumbsup:
PostPosted: Tue Feb 05, 2013 5:43 pm
Standard gearbox will be fairly quick on acceleration, sits at about 3-3.5k at 70mph, cant remember exactly, and it'll top out at about 130mph sat nav speed.
For a more relaxed approach to motorway driving, a diesel box would probably be better as they are meant to have a really long 5th so it'll keep the revs down.
PostPosted: Tue Feb 05, 2013 6:56 pm
I agree with Danny, the 1.6 box is pretty fast up to about 110 but is really noisy cruising. If you sit at 80 it's closer to 4k :(
Not sure how good diesel box is at acceleration but people have said it tops out off the clock so good for top speed and comfortable cruising.
I want to do a hybrid with the 1.6 box and diesel 5th gear. Just need to find a gear puller for uner a hundred quid first to save having to get the blow torch out and heating gears.
Paul
PostPosted: Wed Feb 06, 2013 10:58 am
yep - 80 is 4000rpm as confirmed by Si Turbo :lol:
diesel box isn't bad on acceleration -happypaul will confirm this! but it is much better for cruising :)
PostPosted: Thu Mar 07, 2013 12:43 pm
2.5k at 70 with a erst lsd box, I got 44mpg on a long run once as well, perfect box imo :)
