It is currently Sun Jun 24, 2018 12:08 am
 Post subject: Uprated fuel pump
PostPosted: Tue Oct 09, 2012 8:07 am
Drives: Glaznza v
Hey guys im wondering if it be worth getting a uprated in-tank fuel pump for my 1800 for when I start to tune it? If so would this be a suitable one for the job.
http://www.burtonpower.com/parts-by-cat ... tp050.html
Thanks in advance
Iemke
 Post subject: Re: Uprated fuel pump
PostPosted: Tue Oct 09, 2012 12:27 pm
Hi mate,
Don't think it's necessary for the Fexif i'm honest. Would only be worth doing if your current one is on its way out, and even then a new standard one should suffice.
Unless of course you plan on going mental on it???
Paul
PostPosted: Tue Oct 09, 2012 5:51 pm
Drives: 2litre Si
As said above, unless got problems with yours or looking to push power over 160bhp I would standard one
PostPosted: Tue Oct 09, 2012 7:08 pm
Really, as low as 160bhp? I thought you would need to be pushing nearer 200before it would struggle!
Not based on anything in particular, just thought standard would do more than 30bhp over RS!
Live and learn :)
PostPosted: Tue Oct 09, 2012 8:37 pm
Drives: 2litre Si
I did measure the flow from my standard Si fuel pump once but can't find where I wrote it down, I replaced mine with a 255 pump which is well over the top. there is a rule of thumb on internet.
PostPosted: Wed Oct 10, 2012 7:22 am
Drives: Glaznza v
Cheers for the info guys. I might just replace the pump with a OE one just for peice of mind as I wont be running crazy power for a while
