It is currently Fri Jul 20, 2018 9:54 am
 Post subject: B&M Shorftshift Fitting
PostPosted: Fri Sep 07, 2012 10:08 pm
I have just obtained a used B&M shortshift to fit to my Fiesta Si, I have the gearshift and knob plus some type of collar.
I seen a picture of a new B&M kit on google images, as well as the parts I have it includes 3 short bolts, 3 longer bolts, 4 washers and what looks like a couple of rubber rings or possibly circlips.
I was hoping that somone could let me know where I can get the parts I seem to be missing plus the fitting instructions that come with the new kit.
All help and advice would be much appreciated!
Thanks
Andrew
PostPosted: Sat Sep 08, 2012 7:42 am
Drives: 2litre Si
Have you got a photo of yours from the bottom? If its second hand possibly have all the bits as its all ready put together. I would think when you take standard gear leaver apart it will be self explanatory as It's very basic looks like a case of remove the two torque bolts from bottom to release the self centering springs, unbolt the top of the standard unit and replace with the b&m one refit the self centering bolts. Also worth looking at the linkage at the gearbox end as if this is sloppy will spoil the feel of the short shift
PostPosted: Sat Sep 08, 2012 9:56 pm
what sort of advantages does shortshift give you over standard? and what are the cons?
PostPosted: Sun Sep 09, 2012 10:53 am
Quicker and shorter shift, less effort too. The mk3 gearstick has fuck loads of travel, making that shorter will make life easier because there is less effort.
No cons tbh.
PostPosted: Sun Sep 09, 2012 4:40 pm
why don't you have one bud?
PostPosted: Sun Sep 09, 2012 7:46 pm
Drives: 2litre Si
No cons tbh.
Definitely a lot more positive feel and gear selection like a modern car but if anything I find its more effort due to the reduced lever leverage ratio to get a shorter shift
PostPosted: Mon Sep 10, 2012 1:43 pm
Haven't got around to doing it yet. Plus I cant be fucked to take everything apart to fit one lol
PostPosted: Mon Sep 10, 2012 6:21 pm
expensive as well too!
PostPosted: Mon Sep 10, 2012 8:19 pm
Not if you use a puma linkage or someting ;)
PostPosted: Tue Sep 11, 2012 12:31 am
oo tell more?
PostPosted: Tue Sep 11, 2012 1:02 am
Search it either on here or FT, all the info is around somewhere. Its basically a short shift on the cheap. MK5's and pumas have quite short shifts, so people swap mk3 for puma linkages.
PostPosted: Tue Sep 11, 2012 7:07 pm
ok ta lad!
PostPosted: Thu Sep 13, 2012 10:37 pm
my best mod on my si is my b&m quickshifter without a doubt, piece of piss to fit as well :)
PostPosted: Fri Sep 14, 2012 11:04 am
you get yours brand new phil?
PostPosted: Fri Sep 14, 2012 11:48 am
no mate used for a escort rs turbo apprently b&m dont make them anymore but are made in the states with life time warrenty, I had to strip it right down and put my si gear linkage rods on to it and throw the escort ones away, bought a new circlip from halfords and its perfect :)
PostPosted: Fri Sep 14, 2012 5:14 pm
oh right. so tempted
PostPosted: Fri Sep 14, 2012 5:34 pm
Drives: 2litre Si
i recently fitted a modification kit made for a Mk4 escort as link below, not a straight forward fit but cost under £60
http://www.fiesta-si.com/forums/viewtopic.php?f=5&t=13734&start=200
PostPosted: Sat Sep 15, 2012 6:13 pm
cheers will!
