It is currently Sat Jun 23, 2018 6:22 pm
 Post subject: si springs
PostPosted: Sun Mar 13, 2005 2:07 pm
currently have -35gmx springs but the rear end is solid and every bump shakes up ure spine :(
can anybody reccomend spring sets that are a fair bit softer? yet still similar lowering? or will i have to get the dampers 2? cheers in advance.
PostPosted: Sun Mar 13, 2005 10:13 pm
dampers aswell cos they have a shorter piston in them so giving a better ride quality. just get rears if the fronts are ok mate and give it a try :D
PostPosted: Sun Mar 13, 2005 11:08 pm
cheers, do i have to go gmax?
PostPosted: Mon Mar 14, 2005 2:04 am
Drives: BMW E90 330D M Sport
really stiif springs will knacker your ford shocks in no time mate aswell, trust me i know !
PostPosted: Mon Mar 14, 2005 9:46 am
Drives: V70 T5
you dont necesarilly have to go for gmax, but i'd advise it, they will work better together.
PostPosted: Mon Mar 14, 2005 4:46 pm
gmax springs are designed for gmax dampers but mix and match can work just aswell if not better.
see whats out there mate and dont be afraid to ring up and ask the guys selling em. its their job and they will know better than anywhere else :D
PostPosted: Mon Mar 14, 2005 6:47 pm
cheers guys, will look into it..
95 fiesta si, yeh i know, my fronts are leaking like hell
PostPosted: Mon Mar 14, 2005 8:11 pm
gmax will be one of the cheapest options
PostPosted: Mon Mar 14, 2005 8:32 pm
yeh theyre naff :lol:
by putting dampers that only lower 25mm would i make the ride really soft at the back? and the dampers will max out a lot less?
i probs have the wrong end of the sick
PostPosted: Wed Mar 16, 2005 1:39 am
cheers for all the help guys. may be buying the full set of fronts+ rears + new springs off a mate, will post and let you now how it goes.
PostPosted: Thu Mar 17, 2005 6:57 pm
right then, a mate has offered me a brand new gmax -60mm full suspension kit. but atm its a 35mm drop and the fronts foul only on full lock, is there anyway i can lower it to 60 yet keep the 16s without lots of arch work? would a spacer make any difference? cheers in advance, steve
PostPosted: Tue Mar 29, 2005 10:30 pm
im not a genious but i'd say the lower you go the higher the chances of needing to get those arches out and hack them about a bit
PostPosted: Wed Mar 30, 2005 12:18 am
sorry mate but when you read that back to yourself its like saying
the more it rains the wetter you get
cheers though, looks like im not getting that kit now :rolleyes:
PostPosted: Sun Apr 03, 2005 2:31 am
:lol: yes, yes it is. i retract it and replace it with:
good luck ;)
