It is currently Wed Sep 26, 2018 5:55 am
 Post subject: brakes
PostPosted: Tue Feb 28, 2012 1:56 pm
http://www.fiestaturbo.com/forums/260mm ... -vt193312/
what do we reckon chaps? these are obviously bolt on, but are the gains huge?
and how will a cossie set up compare? and are they bolt on?
 Post subject: Re: brakes
PostPosted: Tue Feb 28, 2012 2:40 pm
Drives: MK1 Focus Estate Ghia
£45 post for brakes is worth it.
But Id rather get new discs as they look shagged.
Could easily run bigger ones for not much more cost :)
PostPosted: Tue Feb 28, 2012 2:47 pm
yeah and pads i reckon paul... do you know if the cossies are bolt on? because i know wango has some
PostPosted: Tue Feb 28, 2012 3:15 pm
Think you have to drill out the hub holes or 12mm, and use a 3mm spacer on the disc for cossies. Same as which you do for most of the upgrades ;)
PostPosted: Tue Feb 28, 2012 3:35 pm
is that including the rs2000's then too? :P ta paul
PostPosted: Tue Feb 28, 2012 3:36 pm
Drives: 08 Ford Focus 2.0
they bolted straight onto an xr2i before but i maybe wrong
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Tue Feb 28, 2012 6:18 pm
Drives: mondeo st tdci
cossies calipers will bolt straight on its the mondeo calipers you need to drill the hubs out for
PostPosted: Tue Feb 28, 2012 6:19 pm
what about rs2000?
i know your the brake man so thats sound lol
PostPosted: Tue Feb 28, 2012 6:20 pm
just not sure the cossie set up will fit behind my wheels, i know the rs2000's will because i have the wheels off that car :P
PostPosted: Tue Feb 28, 2012 7:04 pm
Drives: Like a boss
I'm sure they will mate.. ;-)
PostPosted: Tue Feb 28, 2012 7:45 pm
no they wont. youll need spacers with those wheels. its to do with the shape of the spokes..doesnt need much. 3mm should do it ;)
PostPosted: Tue Feb 28, 2012 11:30 pm
Drives: Fiesta 1.4 cvh
Cossie/mondeo v6 with 278mmx24mm discs will fit under rs2000 wheels with only the 3mm spacer between the hub and the disc, this is a fact as it is what I am running on my car, if I get a chance I'll take a pic and upload it
PostPosted: Tue Feb 28, 2012 11:32 pm
With mondy/cossie brakes you do have to drill the brake pad carrier holes out from 10mm up to 12mm, the standard flexi pipes fit no problem
PostPosted: Wed Feb 29, 2012 12:28 am
Drives: 2.0 fiesta si + mk3 1.1
i may have some v6 mondeo calipers you can have free mate
then you can spend the money on having them properly machined to fit rather than spacers etc
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Sat Mar 03, 2012 10:55 am
thanks tonwah, darren... think i might just go for the rs2000 brakes for ease, but are they a direct bolt on? i dont mind having to space out the cossie brakes if needed and drill them out, but it would save hassle!
