It is currently Mon Jan 22, 2018 11:15 pm
PostPosted: Fri Feb 24, 2012 11:55 pm
ok im thinking about the big brake upgrade.
what year mondeo / granada brake calipers
and what year escort disks
do i need for this conversion please.
wheel size is 15 inch.
cheers sam
TEAM AUBERGINE
PostPosted: Sat Feb 25, 2012 3:14 am
15 inch wheels definitely fit ST24 early version calipers and discs. They're on my car atm.
PostPosted: Sat Feb 25, 2012 4:36 pm
Drives: Fiesta 1.4 cvh
If you do the early mk1 mondeo v6 brakes with those discs you will need hub/disc spacers
PostPosted: Sat Feb 25, 2012 5:15 pm
Yeah with the 15 inch escort SI wheels you need 3mm behind the disc and another 5 behind the wheel! Longer studs needed.
PostPosted: Sat Feb 25, 2012 6:26 pm
Drives: mondeo st tdci
escort cosworth brakes
or the easiest is fiesta st brakes straight bolt on both 280mm
depending on what wheels you have you can run 300mm brakes
PostPosted: Sat Feb 25, 2012 8:39 pm
Doesn't matter what wheels you run you will need to have thoese 3mm disc spacers as the mondeo discs are 3mm different in ofset to the fiesta discs, escort rs2000 5 spoke wheels fit over them fine without longer studs or any wheel spacers, it's a tight fit with only 2-3mm between the spokes and the caliper but fits nicely
PostPosted: Sat Feb 25, 2012 8:41 pm
Could I use escort cosworth discs with mk1 mondeo v6 brake any do away with the 3mm hub spacers??
PostPosted: Sun Mar 11, 2012 9:11 am
escort cosworth cailpers and carries are the same as granada cosworths its just the discs which are differebt due to 5 stud on the grannies
