It is currently Sat Jul 21, 2018 6:39 pm
 Post subject: s2 erst brakes on an si
PostPosted: Mon Feb 20, 2012 8:13 pm
can it be done?
PostPosted: Mon Feb 20, 2012 9:42 pm
Drives: MK1 Focus Estate Ghia
Of course it can.
PostPosted: Mon Feb 20, 2012 10:42 pm
thanks paul! just didnt realise they were the same size, didnt expect that
PostPosted: Mon Feb 20, 2012 11:19 pm
What size wheels you running 15's?
Get some Mondeo V6 ones.. cheap as chips
PostPosted: Tue Feb 21, 2012 5:47 pm
Drives: mondeo st tdci
the offsets are different for the fiesta and they are only 260mm
you can bolt on fiesta zetec s brakes or post 2000 puma brakes which are 260mm and will bolt straight on
or you can use fiesta st brakes 280mm again bolt on
or 300mm mondeo mk3 setup with ground calipers dependant on what wheels your running
PostPosted: Tue Feb 21, 2012 5:50 pm
paul ive heard they're pretty shit and fade and warp quite quickly?
thanks bug g, dont you sell that mondeo mk3 set up with ground calipers? because im running 15's
but yeah if not ill be having fiesta st150 brakes
PostPosted: Tue Feb 21, 2012 7:20 pm
Drives: 2004 Volvo S60 D5
Lol 'bug g' haha xD
300mm setup FTW
PostPosted: Tue Feb 21, 2012 10:54 pm
yes i do sell the 300mm conversion
but will depend on what alloys your running ?
PostPosted: Tue Feb 21, 2012 11:42 pm
Drives: Fiesta 1.4 cvh
I'm using the early mk1 mondeo v6 brakes (same calipers as sierra and escort cosworths but different carriers) and I' using the standard 1.4 master cylinder and servo and they work pretty well, I'm also using the standard v6 discs with 3mm hub/disc spacers.
Is there any other discs I could use with these calipers and not use the disc spacers? The v6 discs are 278mm x 24mm, what are dimentions of fiesta st discs?
PostPosted: Wed Feb 22, 2012 5:42 pm
big g ;) you know what i meant!
standard servo? surely they would be more efficient with a bigger servo?
im running 15" rs2000 alloys buddy. ones in my sig
PostPosted: Wed Feb 22, 2012 10:12 pm
cant fit 300mm's under them due to the curve of the wheel
PostPosted: Wed Feb 22, 2012 10:36 pm
Yep standard servo, works fine, I am planning a mondeo servo when I have time, I'm currently using rs2000 wheels too for the winter and they fit with about 2mm spare, much more room with the gti wheels tho
PostPosted: Wed Feb 22, 2012 11:19 pm
gti, zetec s, and mk5 rs2000 alloys fit 300mm brakes that ive personally fitted
PostPosted: Fri Feb 24, 2012 12:56 am
thats ashame! looks like its st150 brakes ill be going for! thanks anyway buddy,,, but cant be changing my wheels :P
