It is currently Mon Jul 16, 2018 1:35 pm
 Post subject: Gauge pods, where?
PostPosted: Fri Dec 16, 2011 9:16 am
Drives: MK1 Focus Estate Ghia
Right I'm going to add 4 gauges to the si soon.
Oil temp
Oil pressure
Water temp
Voltage
The voltage gauge is not an issue as I'm going to mount that lower down in the coin tray or somewhere like that as its not vital.
The other 3 I want in view while driving.
Will 3 fit on the a pillar with no problem without obscuring visability?
I do not want to lose the heater vents of clock, nor do I want them in the passenger side where the optional airbags fits.
Maybe 2 on the dial surround either side, then one (or the voltage too) on the a pillar?
 Post subject: Re: Gauge pods, where?
PostPosted: Fri Dec 16, 2011 12:39 pm
you can fit 3 on the pillar, i couldnt find a 3 pod when i wanted one so i got 2 on the pillar and monted one next to them on the speedo surround.
i used oil pressure, air/fuel and volts
PostPosted: Fri Dec 16, 2011 12:44 pm
Got a pic?
PostPosted: Fri Dec 16, 2011 1:21 pm
Drives: Jap Crap
There are MOT stations that have failed people on obscuring the view with pillar gauge pods in use, though they are complete jobsworths.
PostPosted: Fri Dec 16, 2011 1:58 pm
If that were a problem I'd just drop the pillar panel for the mot :)
PostPosted: Fri Dec 16, 2011 7:55 pm
yep
pod not fixed properly yet, have heated screen and need to cut space for the tabs on the glass...
PostPosted: Fri Dec 16, 2011 8:54 pm
Hmm not sure I'd get on with that
PostPosted: Fri Dec 16, 2011 9:00 pm
its not soo bad, but you could use the same space where your gonna put you volts guage, i seen a 3 gauge set up that will go in
PostPosted: Fri Dec 16, 2011 9:12 pm
Ebay Linky
should fit nice in the coin tray area...
PostPosted: Fri Dec 16, 2011 11:36 pm
Volts aren't as important so I'm happy for that to be out the way, want the others in view.
Might put 2 around the speedo surround and maybe one on the a pillar... don't want them in the way..
Could lose the heater tho I suppose as I don't use that vent often, and move the clock elsewhere..
PostPosted: Sat Dec 17, 2011 1:41 am
how about getting another dashboard and customising a simple 3 pod gauge holder onto the squared part of the dashboard on the centre of the dash nearish to the clocks would look almost like cosworth style if you know what i mean
PostPosted: Sat Dec 17, 2011 10:49 am
Yeah that's a good plan tbh.
Just need a dash lol
PostPosted: Sat Dec 17, 2011 12:42 pm
yea i like that, only problem i find with guages you want in view, you got nowhere to put em!!!
PostPosted: Sat Dec 17, 2011 1:30 pm
Drives: Jap Crap
my oil temp, pressure and boost are totally out of view which is annoying.
I'm changing them soon though so that my boost is on a pillar pod along with my AFR, and I'm sticking my volts where my boost is now.
PostPosted: Sat Dec 17, 2011 2:21 pm
Drives: 2litre Si
I looked at getting one of these, but the rev counter element would be surplus to you
Multifunction Display Gauge 6 in 1
Link: Ebay Linky
Users browsing this forum: Baidu [Spider] and 6 guests
