Fiesta-Si.com • View topic - 1.6 si loom work with non pas
It is currently Fri Mar 06, 2026 1:42 pm
PostPosted: Tue Nov 22, 2011 12:48 am
right then, i just found out a 1.8 16v xr2i loom wont work with a 2.0 deep ecu, coz the pins are different apparently.
so i guess ill need a 1.6 si loom.
but im not planning on having pas, will the 1.6 loom work without pas?
PostPosted: Tue Nov 22, 2011 7:58 am
Hold on hold on...
Just re-read this...
Get an unmolestered Si loom.. fit it.. job done.
Doesnt affect anything not having any pas pump, as the load from the pas system tells the ecu to up the revs a little... without it plugged it.. it'll run fine.
Another option would be to change the pinout... easier to fit an Si loom.
PostPosted: Tue Nov 22, 2011 4:45 pm
thats whats confusing me, its its a internal edis xr2i 16v it will work fine
but if the pins are different it sounds like its a external edis loom and even with the external edis ecu it wont work coz your car would still be missing the edis on the bulk head
like paul said best way around this is just get a internal edis loom, eg Si 16v
you know i have one waiting for you
PostPosted: Wed Nov 23, 2011 7:42 pm
ill just have that si loom off you sometime jony!
PostPosted: Wed Nov 23, 2011 7:43 pm
the loom i currently have by the way came from a car which had a 2fbc ecu plugged into it.
2fbc internal edis?
PostPosted: Sun Nov 27, 2011 4:11 am
duh, come now danny how many times have i said lol, that ecu is external edis, it wont start your car, wont even crank!
if the loom come with it then the loom wont work either as the edis is still attached to that car is come from on the bulk head, even if you had that it wont fit yours anyway
get a post '94 loom
PostPosted: Wed Nov 30, 2011 7:52 pm
ok ta! i get confused with it all lol
PostPosted: Fri Dec 09, 2011 1:20 pm
How does this stand for me? I'm about to fit a 93 non pats,external edis rs1800 engine into my 96 pats fiesta 1.6 Si. I'm going to use the rs1800 ecu, and was planning getting rid of the si's pas for the RS non pas rack.
What loom should I be using?
PostPosted: Fri Dec 09, 2011 2:10 pm
engines are irrelevant, any zetec will use any zetec loom and ecu (ecu should be matched to the engine size or will run crap)
only thing that needs to match is your ecu to your edis set up, since mk3's all have external pats (or no pats at all) you dont have to worry about the immobiliser
being 93 is difficult, the ecu could be internal or external edis, simple way to know is look at the sticker ont he ecu plug, if it says 2fdc or similar (jumble of letters & numbers) then it wont work on any car from 94 onwards (some 93s)
if it says CULT or similar a 4 letter word, it will work on an internal edis loom, your car being a 96 Si you need the cult ecu (2.0 mondeo deep desk dewy and the 1.8 mondeo blob will also run it fine)
PostPosted: Fri Dec 09, 2011 2:13 pm
oh yea your perfect loom would be an RS1800 from 94 onwards or a 94 XR2i 16v (both 1.8)
Chances are both come without pas
PostPosted: Fri Dec 09, 2011 11:19 pm
the loom i got is an external edis loom with the box thingy on the bulkhead so will deffo need that si loom jony.
as long as its in good nick!
PostPosted: Sat Dec 10, 2011 2:16 am
:) it had a wire tapped into for the mk4 conversion i done but its traceable and simple cut it off, insulate and done
nothings missing from it, shall dig it out and check it over soon
PostPosted: Sat Dec 10, 2011 10:40 pm
ok mate ta
PostPosted: Fri Dec 16, 2011 9:19 am
It's pats not pas btw.
Why not just fit an si or 3.5 rs1800 loom instead of pissing around?
I also noticed a cult ecu being talked about.. good luck finding one if you need one.
PostPosted: Fri Dec 16, 2011 3:01 pm
you really haven't read much of the above have you lol
i know its pats, one spelling mistake, and the loom i have is Si one
PostPosted: Mon Dec 19, 2011 5:53 pm
PostPosted: Mon Dec 19, 2011 6:58 pm
says you who updates with a new plan daily ? :P
