It is currently Fri Jun 22, 2018 12:34 pm
PostPosted: Wed Oct 19, 2011 9:03 am
Drives: Fiesta 1.4 cvh
The Puma axle spacers that you can get from Ford, Ebay and Puma speed, at 10mm, 12.5mm and 20mm thickness, would they fit a mk3/3.5 fiesta
cheers, Tony
PostPosted: Wed Oct 19, 2011 12:34 pm
Drives: 2004 Volvo S60 D5
Only if you modify the hub mounting holes, or get a mk4/5zs/puma beam
PostPosted: Wed Oct 19, 2011 1:20 pm
can you get axle spacers for the mk3?? if not i'll machine some up
PostPosted: Wed Oct 19, 2011 5:16 pm
Drives: mondeo st tdci
they wont fit.
you could take a a pattern of the the mounting face and get a machine shop to make u a set
PostPosted: Thu Oct 27, 2011 4:12 am
you could use the mk4/5 puma ones but the hole would need a fair bit of filing/drilling, making them a bit unsafe
Users browsing this forum: Google [Bot] and 3 guests
