It is currently Sun Feb 25, 2018 6:57 pm
PostPosted: Mon Sep 12, 2011 10:22 am
hi all im pulling the engine out of my zs tonight to put my 2.0 zetec conversion in, im using an efi ho inlet manifold, and piggybacking omex management to run everything, what i need to know is:
do i use the 2.0 zetec engine loom for the crank position sensor, coilpack ect ect and the efi inlet loom for the injectors, icv ect ect?
is it a case of cutting and joining wires from my existing engine loom and swapping them with the connectors from the 2.0 engine loom (e.g. cut the crank sensor connector off zs loom and join the crank sensor connector off the 2.0 loom?)
as much help, info, problems which may occur would be great too cheers
rich.
PostPosted: Mon Sep 12, 2011 10:26 am
Drives: 2.0 fiesta si + mk3 1.1
my 2litre in the si uses the si loom
maybe try get one of those?
isit a n/a engine or turbo? blacktop or silvertop?
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Mon Sep 12, 2011 10:47 am
Drives: Millennium Puma
turbo - i'd consider a full megasquirt set up or something - omex 600 maybe
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Mon Sep 12, 2011 10:50 am
its a 2.0 silvertop turbo. ive got the full engine loom off the donor car i was just wondering do i just cut and join the connectors off the 2.0 loom onto my existing zs loom?
PostPosted: Mon Sep 12, 2011 11:06 am
im using omex 600 management piggybacked onto existing ecu
PostPosted: Mon Sep 12, 2011 11:38 am
i think you need to replace the whole loom with the one from the donor car so basically itl be a mondeo in a zs shell
although i may be wrong :hmm:
the more electronically minded folk on here should be able to help more
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Mon Sep 12, 2011 11:43 am
if its piggybacked the origninal ecu should run the incar functions - so he may just need an engine loom - but i can't say 100%
PostPosted: Mon Sep 12, 2011 12:38 pm
yea thats y im piggybacking it so i dont have to mess about with the in car functions, but obviously i cant just plug the mondeo loom into my existing ecu so i think ill need to keep my zs loom then swap the connectors over from the mondeo loom onto my zs one am i right ?
Users browsing this forum: Baidu [Spider] and 6 guests
