It is currently Sun Jun 24, 2018 2:16 pm
PostPosted: Mon Aug 22, 2011 1:39 pm
i need an uprated fuel pressure regulator for my 2.0 zetec turbo, im using an efi HO inlet and uprated injectors, will this fuel pressure regulator fit on the efi fuel rail? and will it be any good, also does it just replace the old frp or does it have to be plumbed in a different way to the old one ? im not too knowledgeable on things like this so any help or advise would be great
cheers, Rich.
Ebay Linky
PostPosted: Tue Aug 23, 2011 8:33 pm
Drives: MK1 Focus Estate Ghia
are you using sidefed uprated injectors? pretty sure you can just slap a cossie fuel reg on the end of it no probs, although cant be too hard to fix the one you have linked above.
PostPosted: Wed Aug 24, 2011 9:34 am
I have uprated injectors yea would a cossie fuel reg be off an escort cos or saph cos? Or do they all use the same one ? Cheers
PostPosted: Wed Aug 31, 2011 12:16 am
Drives: mk3 si & mk2 mr2
That reg would work but youd need to get a fuel rail adaptor take off to be able to use it
