It is currently Mon Jul 16, 2018 8:07 am
PostPosted: Fri Aug 12, 2011 12:56 pm
hi, im doing a 2.0 zetec silvertop turbo conversion to my mk5 zetec s, im nearly finished but need to sort out feeds and returns for the turbo,
im using a focus rs e/manifold with standard focus rs turbo
i have got a fitting for the sump for the oil ruturn and a t-piece off the oil pressure switch for the feed.
WHAT I NEED IS:
oil feed pipe from t-piece to the turbo (preferably with an inline filter)
oil return from turbo to sump fitting
i am not sure what fitting i need to get or length of hose ect so if someoune could point me in the direction of a kit available to just put together and bolt it on or parts off various cars ect would be awesome!
also if anyone knows how to run the waterfeed for this turbo would be great because i havent got a clue where i get the water suply from (thermostat housing, radiator,...)
all i know is the return can go to the expasnsion bottle, same again with this question, if you could get a link with fittings i will need ect will be much appreciated,
as much info on these questions would be great! i really need to get this conversion finished and this is the only thing holding me up.
thanks alot, rich.
PostPosted: Wed Aug 31, 2011 2:51 pm
Drives: MK1 Focus Estate Ghia
oil feed pipe from t-piece to the turbo (preferably with an inline filter) - Escort RS Turbo oil feed and braided line. Fits into the block in place of the oil sensor thing.
oil return from turbo to sump fitting - drill hole above the oil level in sump, either weld something on or a basic screw/bolt on elbow (think plumbing...) and just a suitable pipe from the turbo, braided or not.
Don't need anything special.
