It is currently Mon Jul 16, 2018 1:46 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 22, 2011 11:06 am
A 260 should fit under the right 14's. The ST24 278mm brakes fit under a 15 very easily so that means the 260's should fit with maybe a tiny grind on the caliper.
PostPosted: Mon Sep 12, 2011 7:38 pm
I have mondeo v6 278 on my escort, cossies discs have hardly any offset so calipers touch the wheels, v6 mondeo discs have 3mm More offset than st170 discs and escort rs2000 discs, mk3 mondeo discs have about 3mm more offset than st170 discs which is better for the mk4 escort but I had to drill the stud holes to 4 stud, I am interested in fitting mk3 calipers under my saphire cossie 15" rims, how much needs trimming off caliper?
PostPosted: Mon Sep 12, 2011 10:03 pm
Drives: Suzuki Ignis Sport
i had the st24 278mm setup on my fiesta, they were absolutely lethal lol dont half stop you! but lock up quite easily.
im gona use a mondeo servo once i rebuilt the car, should make things better. im also using rs2000 rear disc brakes.
PostPosted: Mon Sep 12, 2011 10:19 pm
you can see them on here.
PostPosted: Mon Sep 12, 2011 10:22 pm
they are big!!
PostPosted: Tue Sep 13, 2011 1:21 pm
Rear discs are overkill on light cars, they will lock up easier and cause handling problems, as I found out lol
PostPosted: Tue Sep 13, 2011 4:59 pm
Drives: mondeo st tdci
did u have a bias valve fitted?
PostPosted: Tue Sep 13, 2011 6:22 pm
Yep and its turned right down, aslo got slotted pads! Its stripped out so light at the back
PostPosted: Wed Oct 19, 2011 11:38 pm
oh dear thats what im planning on doing with mine.. :teehheee:
PostPosted: Thu Oct 20, 2011 1:10 pm
its not good for the handling in general to strip out the rear, its only good for acceleration, it upsets the whole balance of the car and makes for a lively back end which can scare the hell out of you at times, I suggest only strip a bit out and move things like washer bottle, battery and header tank to the boot to balance it a bit
PostPosted: Thu Oct 20, 2011 5:15 pm
Drives: Scooby STi and Zaf
They need to be set up so they don't out-brake the fronts. Also your suspension set up has lot to do with how the car behaves under hard braking!
THE FUTURES BRIGHT THE FUTURES BLU :D
Not on my watch..... Pussies!
PostPosted: Thu Oct 20, 2011 9:48 pm
planning on having most of the car stripped but was gona put the battery in the boot and possibly a spare rim in the back like.
ive also got coilovers all round so should be able to get a decent set up with them and im putting a double anti roll bar on the rear end which should keep it stable...
as for the brakes plannning on fitting a bias valve and can set it up using our mot brake tester rollers in work.
PostPosted: Thu Oct 20, 2011 10:10 pm
Drives: MK1 Focus Estate Ghia
Never had any problems running escort servo, 300mm fronts and rs2k rears... on coilovers... on the pickup, with no rear arb, which weighed less on the rear than a stripped out standard car.
People need to learn to drive lol
